465, 4.88's, & 39.5" TSL's
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dodgedude99, Dec 31, 2004.
  1. dodgedude99
    dodgedude99 1/2 ton status
    Jul 12, 2003
    784
    burbia of illinois
    i was going to run the 700r4 that came in my K5 with the 4.88's and the 39.5" TSL's and figured that should be about right/ok for that setup.
    but being that i miss driving a stick i decided to loose the 700r4/208 and swap in a 465/205.
    but after plugging in the numbers into one of those gearing - RPM conversion charts its showing that the RPMS are gonna be way up there if i have to take it on the Highway.
    so my question is i need opinions if i should stick with the 4.88's or swap the 4.10's back in?
  2. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    stay w/ them offroad your not going to want 4.10s on 39s I run them and it sucks
  3. ratzila
    ratzila 1/2 ton status
    Aug 9, 2003
    691
    Mobile,Al
    The 4.88's should be fine. I ran 5.13 with 39.5 tsl with the 465/241. The rpms were a little high on the interstate and gas mileage sucked. I swapped in the TH400/205 with 44's now and the rpms dropped. The gas mpg went up 2mpg:D
  4. dodgedude99
    Jul 12, 2003
    784
    burbia of illinois
    cool, now i just have to get a set of 4.88's for my $150 Pick n Pull Dana 60.
    i wasted probaly $400 rebuilding a Dana 44 (new gears, bearings, seals, ball joints, rotors, axle joints, etc.) figuring i was never gonna find a 60 at the PnP, and wasnt gonna spend the $800 + from somebody else.
  5. MudFlap
    MudFlap 1/2 ton status
    Dec 2, 2002
    250
    Winston-Salem, NC
    4.88's are definetly not too low of a gear. Your rpms will be good on the highway, you are probably not gonna be going 80 mph anyway, so your rpms will stay pretty low.
  6. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Your RPM's should be fine. I have run my 35's and 4.56's in drive (700R4) on the highway and it isn't to bad as long as you stay around 60-65. I can't go faster but with a 39.5 and only a little more gear you should be fine. My tires only measure a true height of 33.5-34".
    Harley
  7. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    I run 4.88's and 39.5 with th400/203/205 65-70 is about it for any lenght of time that puts me around 2900- 3200 depending on head wind and hills. That gear was fine for offroad but I wanted more, much like you will get with the 6.55 first gear of the 4 speed.
  8. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    2wd leveling kit for my 04.5
    anyone have one? and a link to where i can buy one? i would prefer steel, but would go wioth t-6 aluminum as well.....
    im going to need it for the 315's and the air bags for when i pull.
    thanks
    Grant
