465 and eaton questions
Discussion in 'The Garage' started by 69K5, Oct 23, 2003.
  1. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    finally got the cover off the 465 and not a drop of fluid in it. look here and see if its workable please. its still doesnt want to shift except reverse but its getting looser. maybe just put some fluid in it and work with it to loosen it up?
    also please look and see whats in the eaton. im not sure what it is if anything.
    sorry the pics suck but so does the camera. /forums/images/graemlins/grin.gif
    thanks /forums/images/graemlins/thumb.gif
    69k5 /forums/images/graemlins/k5.gif
  2. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    fill er up with PB blaster and wait a few hours, then try rotateing the input or the output shaft to see if you can get things turning inside, looks like only surface rust, but im not a garu in these situations, but my 12 bolt had some surface rust on it when i got it on the gears i just sprayed it down with wd-40 and then brake clean and then filled it up and drove with it. and that diff looks like a detroit, of corse im probly wrong, someone else can filed the diff question. /forums/images/graemlins/thinking.gif
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  3. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,603
    555
    Wasilla AK,
    fill the whole case with marvel's mystery oil and soak the the top cover in it also it'll free up
  4. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    thanks. alll the shaft turns. i will just have to gobuy some more marvelmystery oil and fill her up. its only surface rust no pitting or anything. i hope it works out good.
    i took the diff cover off and it didnt have anything stamped on the ring except
    YY and B9 wth??
    the pinion end i could see said
    934642-7-32 any ideas on this? i was just trying to see my gears. i cant see the pinion enough to count the teeth on it. guess if no one knows ill pop the d44 up front and see.
    thanks again
    69k5
  5. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    bump
  6. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Make sure the 465 will spin in all different gear combos (just manually move the shift collars on the main shaft to select the differeent gears...If everything spins, spray some PB Blaster on the shift rails on the top cover and try to free them up...the top cover is pretty easy to rebuild in a short amount of time...maybe pull it apard and clean off the shift rails...
    Don't know much about eatons, but I think they are pretty cool...
  7. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Take some carb cleaner/brakekleen, and on the very nose of the pinion shaft, it will have the gear ratio stamped on it.
    By nose I mean, where the pinion come's in contact with the ring gear. Kinda of a pain to see, but it's there. A flashlight come's in handy too. /forums/images/graemlins/grin.gif
  8. cornfed
    cornfed 1/2 ton status
    Oct 15, 2001
    295
    washougal wa
    If your asking if the Eaton is a detroit or not look at the diff on the side the ring gear bolts to. There is some inspection holes - look and see if you see a spider gear. If you do it is open and if not you have a factory no-spin ( detroit) in it.
  9. MEPR
    MEPR 1/2 ton status
    Oct 21, 2002
    1,546
    McChord AFB
    if push comes to shove, its an eaton you can pull the whole diff realy easilly. Thats the beauty of third member axles /forums/images/graemlins/thumb.gif
  10. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    don the "nose" had this stamoped on it
    934642-7-32
    cornfed
    im not sure what apider looks like exzactly. i remember the whole and saw domething that looked likea round gear about 2 inches in diameter with teeth. sorry ive never opened up an axel before
    thanks
    69k5
  11. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    32 div by 7 = 4.57 so it has 4:57"s for gear.
    If You saw the "side gear's" it's an open differential. Detroit/No-Spin, are just round, no teeth, when viewed through the inspection hole's.
  12. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    don
    thanks for clearing that up i wasnt sure which numbers to divide. at least i dont have to worry about gears for the upcoming lift. /forums/images/graemlins/grin.gif and its open no biigie. i kinda thought it was b/c i had it jacked up and was spinning the tires and then jerking it one way and the other looking for a reaction in it.
    this doesnt sound like the shakespeare im supposed to be studying does it. guess i better get to work.
    thanks again
    69k5
  13. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    well with dons knowledge and math on the rear end I know its 4.57 After inspectin the fron end today it says they are 4.55 if im correct that comes out to 4.56! at least i dont have to worry about gears when i go to 35's. where is that rpm chart at for gears ?
    69k5
