465 bellhousing ?s
Discussion in 'The Garage' started by broncoman6524, Feb 4, 2007.
  1. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    sooo sm420 and 465 DO NOT have the same bellhousings:rolleyes: lol. anyway i need a bellhousing for my 465, which one should i look for? is there a better one than the other? ive heard of pass and driver slaves. this is just where the shift for goes in correct? i need a drivers side one i think. What would be better for the clutch, manual or hydro?
    and finally whats the manuf # for the correct one? sbc-sm465?
    thanks guys. ya kinda noob questions but w.e. lol
  2. YZEATER
    YZEATER 1/2 ton status
    Jan 21, 2005
    2,358
    TARENTUM, PA
    gm part # Bell Housing 15530202
  3. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    The older cast bells are stronger than the newer allumin. ones...that is about all I know...:rolleyes:
  4. skyyk5
    skyyk5 1/2 ton status
    Jan 2, 2007
    1,537
    N.E. PA
    I Like the hydro. If you are going with a pass drop, then you want a driver slave. If going with a driver drop, then a pass slave (I have one). The pass slave is to close for comfort to the pass drop drive shalf. But if you are puting a real motor and trans into say a Bronco, but keeping the driver drop, then you need a pass slave.
  5. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    what exactly is the diff between pass and drivers slace? besides the obvious...im basically building a 51 ford truck with chevy running gear fram etc. soo alot of this is gonna get fabbed up...
  6. skyyk5
    Jan 2, 2007
    1,537
    N.E. PA
    Nothing,But the location of the slave. I have a pass side slave if you are going to keep the truck with a drive drop.
  7. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    ok driver drop but pass slave? im confused...lol i though the clutch pedal was attached to an arm which connects to the fork. ie always on drivers side? or am i retarted :) LOL
  8. skyyk5
    Jan 2, 2007
    1,537
    N.E. PA
    I am sorry should have explained better, My fault. When I say pass slave it is for a hydro bell. Hydro bells have slave cylinders, Manuals just have a fork and some have pivots too. So they made hydro's with the fork and slave on the driver or pass side. A good thing to remember is that the slave (if hydro) should be opposite of your drive shaft. Ex. pass drop driveshalf/ driver slave. Yes a man. bell has the linkage type, And I have never seen a pass side fork on a man bell. Sorry again about the confusion. Hope this clears it up for you.
  9. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    gotcha taht makes perfect sense. now. this i just a mud truck soo no hydro. guess i need a drivers fork assy. right?
  10. skyyk5
    Jan 2, 2007
    1,537
    N.E. PA
    you using the driver drop (stock f*rd) driveshaft? If so Id run a hydro pass slave bell. Instead of messing with linkages.
  11. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    i mean to say that this is a 70s blazer frame and runnin gear. that im puttin a 51 ford truck body onto. is hydro realy taht much easier?
  12. skyyk5
    Jan 2, 2007
    1,537
    N.E. PA
    yea your right there.
  13. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    gotcha im no where near even having to worry about setting the clutch up lol. im in the process of goin through axles and sanding/painting frame...so thatll be a while lol
  14. skyyk5
    Jan 2, 2007
    1,537
    N.E. PA
    Well good luck with it. Sounds like a cool project.
