465 clutch and flywheel
Discussion in 'The Garage' started by az ranger, Feb 11, 2005.
  1. az ranger
    az ranger 1/2 ton status
    May 9, 2004
    139
    Safford AZ
    I am at the point in my swap where I need to get clutch and flywheel, but I need advice. I did a search and most people seem to like luk clutches, so I plan on getting a 12" luk pro gold still not sure on diaphram or 3 finger style I wont be in mud that often if it matters it will be mostly rocks and dirt with a lot of dust.
    For flywheel should I just go to napa or checker and ask for a flywheel for an 88 jimmy with a 350. what about teeth count what else do I need to know.
    thanks
    scott
  2. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    I just went to schucks for my flywheel. As long as it is for the same year, I don't think you should have a problem bolting to the crank or meshing with the starter.
    I think I would go with a diaphram clutch, though I'm not sure why...:dunno:
  3. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Get a diaphragm clutch. The Borg & Beck style take way too much effort to disengage, and it is extremely hard on the crappy linkage that these trucks came with.
  4. k5redneck
    k5redneck 1/2 ton status
    Jun 24, 2004
    1,000
    mesa AZ
    what he said:grin:
  5. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    I knew there was a reason, thanks for the reminder.
  6. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    yea go with the diaphragm clutch, the 3 finger ones get old after a while, also i wouldnt recomend the autozone clutches, the springs pop out and the disk shatters, but they do have a lifetime warrenty (until they see the truck its in):D
  7. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    168 tooth flywheel
    And yes diaphram is much much better:D
