465 Clutch rod?
Discussion in 'The Garage' started by yoshisv, Oct 17, 2006.
  1. yoshisv
    yoshisv 1/2 ton status
    Feb 19, 2006
    266
    Hartsville, Tennessee
    Does anyone make a stronger replacement clutch rod for a truck with a sm465? Thanks.
    Chris
  2. sweetk30
    Nov 1, 2004
    25,540
    539
    horseheads , ny 14845
  3. yoshisv
    Feb 19, 2006
    266
    That should do it. Thanks:waytogo:
  4. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Is there a problem with the OEM clutch rod? I've never had a problem with it.
    After 200k mi, the ends are a little worn and got sloppy, but that's about it.
    I put a brand new one in during my Frame off.
    My buddies truck had realy rusty body mounts, every time he pressed the clutch, his body would lift off the frame a little, but no problems with the rod?
  5. yoshisv
    Feb 19, 2006
    266
    The ends are worn so bad that they are about to break off.
  6. diesel4me
    Jul 24, 2003
    17,553
    939
    Massachussetts
    reinforcement!..
    I've slid over and welded a hunk of 1/8" pipe or 3/8"rebar on a few rusted clutch linkage on plow trucks,to get some more use out of one...had to weld a brace on the "Z" bar on a few trucks with 12" three finger pressure plates too--they flex and eventally crack if you leave it stock...:crazy:
