465 conversion question: Clutch pedal?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Thumper, Mar 3, 2003.
  1. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    I just finished putting in the pedal assembly. It went well, a couple of cuss words, but overall not too bad. I dont have the tranny in yet, so there is no linkage or anything attached to the clutch pedal besides the spring. My question is: did I do it right? The clutch pedal right now is sprung up towards the driver just fine. When I press it a bit, it goes down, then reaches a point where the spring pulls it all the way down and it wont come back up on its own. I can pull it up easily, and it stays up, but I was wondering, is this the way it should be with no linkage or anything? I am curious thats all. Its in the only way I can see it can go, so I am not worried, just unfamiliar with the way it should be. The clutch itself will force the pedal back up when its installed right?
    Mike
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    My clutch pedal, if I press it ALL the way down hard, sometimes gets stuck. You have to press really hard and try to get it stuck to get it stuck.
    Even if I slammed down on the clutch pedal in an emergency, it would not be enough to get it stuck. You really have to try.
    Maybe when you get the tranny and linkage in, it will provide more resistance.
    -- Mike
  3. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    with no linkage or master cylinder hooked up to it, yes it will be that way...My clutch pedal assembly had a broken return spring so I tossed it..when I installed the pedal assembly with out the master hooked up, it just swung back and forth...as soon as the master was on, it came back to its original position,...oncy you hook it all up, it will be fine...
    Chris
  4. BigBen
    BigBen 1/2 ton status Premium Member
    Nov 14, 2002
    1,194
    Grand Haven, MI
    That's exactly how mine was before hooking everything else up.
    Mine is working fine. /forums/images/graemlins/thumb.gif
  5. Thumper
    1,582
    Alberta Canada
    Awesome, thanks guys. Thats what I thought but wanted to make sure. I shoulda mentioned its gonna be a mech setup. Now I have to get the tranny in. I have been avoiding that cause I think I may have to do both driveshafts... ewww. Oh well, this week is the plan.
    Mike
  6. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    What you are describing is the action of the over-center spring. Perfectly normal. You'll be glad its there if you're using a big nasty 3-finger clutch /forums/images/graemlins/thumb.gif
  7. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Mike
    On the driveshafts it depends on what you're pulling out and putting in. In my '70 K5 I pulled a TH350/NP205 and put in a SM465/NP205 and the DL length was the same.
  8. Thumper
    1,582
    Alberta Canada
    I am yanking a th400/ 205 and putting in a 465/ 205. Measureing it on the floor it looks like the rear shaft will need to be about 3" longer. But I will have to wait for the final answer when its in.
    So, that spring is only an overcenter spring? I kinda figured it would be a return spring of some sort. Cool, I feel better about it now! LOL
    Thanks for the responses guys,
    Mike
  9. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    Two words for ya Mike..."Diaphram Clutch"
    I've had both with the mechanical linkage the the 3 finger style is brutal, stiff, and grabby compared to the diaphram style. I could easily drive in heavy traffic now without cringing at every gear change.
    rene
  10. Thumper
    1,582
    Alberta Canada
    Really... there is that much difference huh? I dont have the $$ for a new clutch yet, so I was going to toss in the one that came with... it looks like it should last a few months, maybe I will go with the other style when the time comes. Whats the diff in price? I got quoted 207.00 for the finger type today from NAPA.
    I just cant believe its finally going in. I got the pilot bearing today, and some gasket for between the two. Prolly in this weekend. I need another set of hands for the job... /forums/images/graemlins/smile.gif
    Mike
  11. wfo163
    wfo163 1/2 ton status
    Jan 11, 2003
    100
    Charlotte, NC
    Huge difference! Make sure you get the diaphragm type. My truck had the 3 finger leg press machine as well and was one of the first things I got rid of. Yeah, too grabby and hard to slip the clutch for those slow rolling starts, seemed that it wanted to jump up from the floor. Now it presses with slightly more pressure than my vw and makes traffic much easier to deal with.
  12. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    For the love of god don't buy a Napa "RAYLOC" brand clutch. You would be better off getting one from the junk yard.
    Summit or Northern have good prices on clutch kits. I think my RAM clutch kit (clutch, PP, TO Bearing, Tool) was about 125 bucks.
  13. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    You should be able to find a pressure plate clutch and TO bearing for under $180 cdn...
    Do not let them push you into a Borg and Beck 3 finger clutch...they suck major ass.
    I can't recall off hand what type of pressure plate came with that set-up I sold you.
    Rene
  14. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Hey, at the Napa I work at, we only sell LUK clutchs...I can get you a deal on the RepSet diaphragm-style if you want...Like $98...That is the disc, pressure plate, TO bearing, pilot bearing, alignmet tool, and grease...I can get you the ProGold set to but it is $190...Still cheaper than the list on $300+ for the ProGold...
    Chris
  15. dyeager535
    26,978
    I paid about $125 (US) for a "Sachs" diaphram setup, complete. Seems to be good quality, has held up for a couple of years, and yes, it's ten times better to drive than the 3 finger setup I've tried. (granted, 454 in a 6000lb truck with a semi lopey cam, but still, my 350 setup works better in any case, ease of use, ability to slip it, smoothness, etc)
    Kinda funny a clutch coming from a company famous for bicycle chains, but if it works, it works.
    I had the spare parts lying around too, but I couldn't see myself throwing a used, perhaps warped flywheel, and used clutch/pressure plate combo on the truck since I didn't want to mess with it again any time soon. Kinda like throwing used disk brake rotors on something you plan to drive all the time I guess.
  16. u2slow
    May 9, 2001
    2,217
    BC Canada
    I had a chance to drive a '62 3/4-ton with the factory hydraulic clutch and 12" 3-finger clutch. Nice and smooth with no leg twitching... then again - the slave cylinder on these looks just like a wheel cylinder for drum brakes /forums/images/graemlins/thumb.gif
  17. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    I have a "Rhino" diaphragm clutch in my Suburban. It cost under $150 for everything, and seems to hold up behind a big block just fine. The pedal is really light...even lighter than my friend's Suburban with hydraulic clutch linkage.
  18. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    I've been real happy with the Moroso Brute Forse diaphram type in mine.Less pedal pressure and exelent hookup.No probs with slipping even with 38s. /forums/images/graemlins/thumb.gif
