465 driveshaft swap ?'s
Discussion in 'The Garage' started by jaredmajor, Apr 3, 2006.
  1. jaredmajor
    jaredmajor Registered Member
    Mar 2, 2005
    96
    Anchorage, AK
    yes i did search and didn't find what i was looking for. I have a 350/203, it's a k10 shortbed, i am swapping in a 465/205. I already have the front driveshaft, but do i have to shorten or lengthen my rear driveshaft? A search didn't come up with the exact answer, but i am shure this has been covered a million times.:rolleyes:
  2. jaredmajor
    Mar 2, 2005
    96
    Anchorage, AK
    anybody? I know this swap has been done a thousand times, somebody has to have the answer. I know a 205 is shorter than a 203. It looks to me like the 465 is shorter than the 350.
  3. BigBen
    BigBen 1/2 ton status Premium Member
    Nov 14, 2002
    1,194
    Grand Haven, MI
    I swapped a 465/205 in for a 350/203 in my '74 K5.
    Stock Driveshaft wasn't long enough.
    Had a new one made.
    Hope that helps.
  4. jaredmajor
    Mar 2, 2005
    96
    Anchorage, AK
    yes it does, how much to get a new one? I was hopin this was going to be a cheap swap, but no. Seems like alot of these swaps aren't cheap.
  5. onlychevy6
    onlychevy6 1/2 ton status
    Mar 29, 2003
    1,293
    Hockley, Texas
    not that this is much help. But in my 75 350/205 i put the same shaft that was from my 78 that was a 465/205. also had a 6" lift.
  6. Scrubby
    Scrubby 1/2 ton status
    Dec 1, 2001
    114
    Boise, ID
    The 465/205 combo is the same length as the 350/205 combo, so I would think that a 203 would be longer. I would imagine you have to lengthen the rear drive shaft. When I did my lift, I had to have both the front and rear lengthened. With all new U-joints, CV rebuilt, slip rebuilt, and balancing, it ran me $400 at the local driveline place. For just the rear without any joints or rebuilding, I bet your looking at around $100. I could be wrong though.
  7. jaredmajor
    Mar 2, 2005
    96
    Anchorage, AK
    thanks, that helps, seems like this swap may be a little bit of a ways off now. I still have to get a clutch and pedals and master and slave cylinder and that braket from AA to keep my bellhousing.
  8. jaredmajor
    Mar 2, 2005
    96
    Anchorage, AK
    I've heard that some of these k5's with 700/241 that swapped to a 465/205 didn't need to swap their driveshaft, that so? Maybe i can get one from a junkyard for cheaper.
  9. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,229
    FrankFort IL
    well if you need pedals i have ma set make me an offer i also have a master and slave if you want it all came out of a working 89 k30 make me an offer and we will see what we can do i have mechanical for now and if i do any more trans mods it will be an auto i think
  10. jaredmajor
    Mar 2, 2005
    96
    Anchorage, AK
    i assume thats all hydro? What about a bell housing, this is part of my problem. I live in alaska, lots of trucks, just not the parts i need anywhere. I want to do hydro, but have not luck finding a stock set up around here. I hear about all of these adapters like AA and pedals from CNC. I would like a hydro set up, fairly cheap. Would this set up work with my stock bellhousing with an adapter?
  11. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    i beilieve it does i have all but bellhousing i was looking for one but no luck
    but that is everything needed pretty much minus the bellhousing and throwout bearing
  12. jaredmajor
    Mar 2, 2005
    96
    Anchorage, AK
    no bearing no problem. I know AA makes that adapter, but can i use it on the stock master cylinder?
  13. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    i think so not totally sure tho since i never did swap
