465 flywheel/clutch ?
Discussion in 'The Garage' started by lamberthkp, Feb 27, 2006.
  1. lamberthkp
    lamberthkp SITFU Premium Member
    Jan 17, 2005
    1,468
    16
    West TN
    on the 18th of next month im putting my 465/205 in my blazer.
    the tranny is the 10splin out of a 79 ,1ton i think. it is going in a 89blazer with tbi350 just wondering what size flywheel and clutch i needed to buy for this i did'nt know if i need one for 89 or 79 or what? any help would be great thanks ,Keenan
  2. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    I think the clutch is the same for either one. Only difference being mech over hydraulic.
  3. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    You will need the truck type flywheel that has 168 tooth count and it must be for a one-piece rear main seal style crank pattern.
    Tom
  4. Robert79K5
    Robert79K5 1/2 ton status
    Mar 23, 2003
    335
    Douglasville Georgia
    Yup what he said. Cant use the old style flywheel from the two piece main seal engines.
    The good news is I went to Advance Auto and they had one on the shelf for right around a hundred bucks. :waytogo:
  5. lamberthkp
    Jan 17, 2005
    1,468
    16
    West TN
    awsome thanks , so if i just buy the clutch that matches the flywheel im good right? :D for the hydro setup that is.
  6. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    yes, should be 12", and make sure the spine count of the disk matches the input shaft
  7. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    Some parts houses might list the 12" clutch as an 11-7/8" but do not woory - it is the same animal.
    Tom
  8. lamberthkp
    Jan 17, 2005
    1,468
    16
    West TN
    good to go! just wanted to make sure of everything before i bought it and put everything in and dont work, or run into a problem. THANKS for the help should make everything much easier for me. :D
  9. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    If you have a little extra money for the clutch, go with a 12" Luk pro gold. Best clutch I have ever used by far.
  10. lamberthkp
    Jan 17, 2005
    1,468
    16
    West TN
    ya i need a really good clutch should have plenty of cash for all of it.
    i'll go check it out .thanks
