465 hard to get in to reverse
Discussion in 'The Garage' started by slowk5, Oct 24, 2005.
  1. slowk5
    slowk5 Registered Member
    Oct 14, 2005
    72
    gladstone oregon
    i just got my 465 tranny back from the 4x4 shop that rebuild it. havnt put in in yet,but i was playing around with it and its really hard to get in to reverse.will it shift in to gear better when its in the truck and has oil in it? do i need to take it back to the shop and have them look at it?i dont want to put it in and find out theirs a problem! hope its normal .
  2. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    well, reverse has no syncros, so it will be harder, also, in the vehicle it will have oil, and, if needed, you can let up on the clutch to spin the shaft
    once it goes into reverse now, will it go out and go back in ok?
  3. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,925
    337
    Fort McMurray, Alberta
    With my 74, I sometimes had the gears lined up just perfectly so that the truck wouldn't go into reverse. Just pop it into third, then it'll usually go into reverse after that (don't need to let go of the clutch)
    Or, you can do it the nasty way, just let the clutch go a bit, then when it starts spinning, clunk her in, lol :doah:
  4. sweetk30
    Nov 1, 2004
    25,549
    543
    horseheads , ny 14845
    take it back now and get the rubber gear option . this will help make the non syn gears be much quieter. :haha:
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Yep, there are no synchros on 1st or reverse in a 465. If you press the clutch (with the engine running) and shift to 2nd, 3rd, or 4th before you shift into 1st or reverse then you won't get that nasty grind that I hear folks with 465's perform far too often... :rolleyes: :doah:
  6. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Hehe....like learning to drive a Semi
  7. Russell
    Jun 23, 2000
    7,925
    337
    I always felt like I was driving a school bus when I was rippin' around town in my 74 :)
    I miss that truck, lol -- I'm planning on putting either an SM465, or an NV4500 into my 80 to make it feel a bit more like the 74 :)
    Never shoulda traded that 74 for the peice of junk 89...
  8. slowk5
    Oct 14, 2005
    72
    gladstone oregon
    then u dont think i should worry about it?it goes in but it takes all little work,ill get the hang of it.forgot its not out of a bmw. thanks for the help!
