465 help please...
Discussion in 'The Garage' started by walla2k5, Apr 4, 2005.
  1. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    I need some help with my tranny swap.I've never worked on a 4sp. before and after I bolted everything up including the transfer case ,what a pain,the shift fork is real sloppy.It moves all around( but doesn't pull off the throw-out bearing,I think ). 1) Is this normal???
    2)Also need a place to hook the return spring.
    3)Isn't there a little spring that hooks to the shift fork and the clutch rod???I don't seem to have it.
    I've done a search but haven't found anything yet,this is really holding me up.
    Any help would be greatly appreciated,maybe a pic of where these springs go....
    Thanks in advance,you guy's have been a BIG help with my project so far!!! :thumb:
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i always just retain the real long spring from frame rail to fork arm
    usually there was a small spring on the linkage yeah but rarely is intact after all these years and i run without the spring just fine on my rigs,
    fork sloppiness is common, theyre all like that, anything with any real miles on it,
    normal, no worries,
    unless it jams or hangs up or something ? then may be time for new fork or something,
    good luck
  3. walla2k5
    Sep 5, 2004
    2,054
    Walla Walla, WA
    Thank you my friend....I can sleep better knowing all is well. :thumb: :usaflag:
