465 or th350???
Discussion in 'The Garage' started by 69K5, Jan 6, 2003.
  1. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    I know its a debated question but i wanted some more opinions. the donor truck is a 72 k20 with 465 and np205, and the blazer has th350 9needs rebuilt) and np205. whats everyones opinions? rebuild the 350 or swap the 465? can you check the 465 w/o hooking it up?? the gut says it used to work but its been parked for a while.
    thanks
    nathan
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I would go with the sm465/NP-205 combo. I plan on doing that conversion in the future with my K5.
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    465's usually don't go sour from sitting.... unless the shifter has been taken out and it filled up with rain /forums/images/graemlins/blush.gif
    IMO, only thing the 205 from the TH350 is good for is a TH700 swap for a daily-driver rig. I would stick with the 465 - essentially bomb proof. /forums/images/graemlins/smirk.gif
  4. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    u2slow
    i think i am going to go with the 465. i just like shifting. and when im mad theres nothing better than jamming gears. this is the first automatic i ever owned so im used to standards anyway. my truck will be a daily driver unless its raining or really cold, then i'll take the car.
    thanks again
    nathan
  5. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    Go with the 465!!!!I swapped to it a few months ago,the auto sucked!!I have 4.10 gears and run 39" TSL's with no problems!!"Granny" gear is unusable unless you are off-road!
  6. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    granny is also useful in traffic, you dont have to push in the clutch as often, and you dont move as fast as if you were in 1st, and it makes people wonder why you start accelerateing so slow /forums/images/graemlins/thumb.gif.
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  7. MEPR
    MEPR 1/2 ton status
    Oct 21, 2002
    1,546
    McChord AFB
    i hope to get a 465 for my luv v-8 swap. One of my buddies has a 465/ 205 combo and it runs realy good, i would recomend this especially if your used to sticks
  8. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I've run both and I went with the auto for mud racing. Helped too.
  9. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    what and how many gears are there in a 465? 123 and r??I think i am gonna swap b/c i have both t cases. i am gonna do that and twin stick the 205 also. everyone seems to like the 465 the most.
    thanks
    nathan
    69K5
    thanks
    nathan
  10. BLUESMAN
    Oct 3, 2001
    951
    There's the "granny"/lo gear which is a 6.55:1 ratio.The only time I use it is when I'm waiting in a huge line on the street.When you throw that bad boy in granny and 4 lo.....you can walk faster than your truck will go!!I have 70:1 crawl ratio(got the 208 case).
  11. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> If you try to jam the gears in a 465 and there's likely to be more grinding than jamming. /forums/images/graemlins/eek.gif Definately not a race car tranny... /forums/images/graemlins/thumb.gif </font color>
  12. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    Shaggy
    i will have to remember that. im still tryimg to outgrow doing that. /forums/images/graemlins/rotfl.gif
    nathan
    69K5 /forums/images/graemlins/k5.gif
