465 output shaft HELP!
Discussion in 'OffRoad Design' started by Batmanjr, Jan 21, 2002.
  1. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    Stephan,
    How far does the 32 spline output shaft extend from the 465 transmission. I'm doing a 32 spline doubler kit and and found someone to shorten my long shaft to work with a rare 465/203 adapter, but since I don't have the shaft in the transmission, I can't measure the exact length it sticks out to know how much to shorten it. HELP! If you had a 32 spl 465 and put a 32 spl 203 on the end of it, how much space would be between the two housings? Thanks
    <blockquote><font class="small">In reply to:</font><hr>
    <font color=red>My Wife:</font color=red>"Only two minor cosmetic problems: The inside and the outside!"
    <hr></blockquote>
    1972 K5 6.5L,465,203/205Doubler,14FF/D60
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    What input gear are you going to use on the NP203? Keep in mind that the splines are rolled on the 465 shaft so you can't cut a 32 spline end on it after you cut it off. That might be the most important point here.
    Making the world better, one truck at a time.
    SW-ORD
    <a target="_blank" href=http://www.offroaddesign.com>www.offroaddesign.com</a>
