@%#$% 465 problems
Discussion in 'The Garage' started by greywolf, Jan 21, 2004.
  1. greywolf
    greywolf 1/2 ton status
    Oct 18, 2001
    1,606
    ST.PAUL TX USA
    i took my shifter off and when i put it back nothing no gears i know this should be easy fix but it no workie /forums/images/graemlins/confused.gif /forums/images/graemlins/1zhelp.gif
  2. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Did you have it in neutral when you pulled it out? Maybe it's just not lined up properly
  3. greywolf
    Oct 18, 2001
    1,606
    ST.PAUL TX USA
    i thought did? but if i didn't how can i fix?
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    wouldnt be able to put in neutral anyways if was jammed, its no fun sometimes unlocking it
  5. burbBoy
    burbBoy 1/2 ton status
    Feb 4, 2002
    358
    WI
    Grab a flashlight so you can see down the shifter tower on the tranny. All the shift rail slots must be lined up in the center to put the shifter back in. If one is off try and persuade it to the neutral spot with a large screwdriver.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yep that's how you do it. Usually not too bad to get the shift rails to move in there with a screwdriver.
  7. greywolf
    Oct 18, 2001
    1,606
    ST.PAUL TX USA
    thanks guys /forums/images/graemlins/thumb.gifi'll fix it sunday
