465 Question
Discussion in 'The Garage' started by Currank5, Jan 25, 2007.
  1. Currank5
    Currank5 1/2 ton status
    Apr 4, 2006
    244
    South Dakota
    What is the difference between a 2wd 465 and a 4wd 465? If there is a difference can you make a 2wd version fit a 4x4 application?
  2. skyyk5
    skyyk5 1/2 ton status
    Jan 2, 2007
    1,537
    N.E. PA
    the difference is the output shaft, and the tail housing instead of a t-case adaptor. you can convert it yes, but with the trouble, might as well just buy one. If you want a 32 spline output, it will cost you yo get that output shaft plus the trouble of switching it out. Then you need a adaptor and t-case. After all that $ you could pick up a 10 spline with a 205 for half the cost.
