465 Shifter Jams
Discussion in 'The Garage' started by RSNHELL, Jan 18, 2005.
  1. RSNHELL
    RSNHELL Registered Member
    Jan 17, 2005
    53
    SANTA ROSA,CA
    HEY EVERYBODY. ANYBODY HAVE A PROBLEM JAMMING THE SHIFTER BETWEEN 2-3. HAD TO TAKE OFF SHIFTER TWICE AND MOVE RAILS WITH A SCREWDRIVER TO FREE IT UP. I'VE ONLY HAD IT IN FOR A COUPLE OF MONTHS (REBUILT). ALSO ALOT OF SLOP IN SHIFTER . EDUCATE ME PLEASE. THANKS ,RICK. ALSO WANT MEMBERSHIP (I really am computer illiterate,thanks)
  2. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    Sounds like the rebuild job wasn't as thorough, as you expected!:(
  3. RSNHELL
    Jan 17, 2005
    53
    SANTA ROSA,CA
    I figured as much. Couldn't be the shifter being worn and /or grabbing something.i HAD THE TRANNY SWITCHED FROM 2WD TO 4WD BY CHANGING THE OUT PUT SHAFT /NEW BEARINGS AND SYNCROS. TRANNY GUY SAID EVERTHING ELSE LOOKED GOOD.
  4. dyeager535
    26,982
    191
    How does the end of the shifter look?
    Some of them break the weld, which will loosen the shifter up a fair amount.
    I kind of doubt that will solve the binding issue, however, if the shifter is more positive, it *may* stop it from happening.
  5. mr_beer
    mr_beer 1/2 ton status
    Sep 10, 2004
    325
    Mt. hermon LA
    check the o-rings in the end of the shifter, just drive the roll pin out and there suppose to be 2 o-rings around the end
  6. RSNHELL
    Jan 17, 2005
    53
    SANTA ROSA,CA
    tALKED TO THE TRANNY GUY ,AND HE SAID ITS COMMON FOR THOSE SHIFTERS TO DO THAT IF THEY ARE SLOPPY, BECAUSE THEY'LL GET CAUGHT BETWEEN THE TWO SHIFTER RAILS. IF I DO RECALL I DIDN'T SEE ANY O-RINGS EITHER. I'LL SEE IF I CAN GET THE PARTS AT THE DEALER, OR AT LEAST GET A DIAGRAM(DIMENSIONS SO I CAN FAB ONE UP) THANKS FOR THE INPUT. I'LL KEEP YOU INFORMED. P.S. GLAD TO BE HERE.
  7. rcurrier44
    rcurrier44 1/2 ton status
    Oct 13, 2003
    320
    Anyone got the specs on the o-ring or a link? I have had the same problem a couple of times with mine.
  8. mr_beer
    Sep 10, 2004
    325
    Mt. hermon LA
    I just used o-rings that fit kind of snug. I have a assortment box of them, so I just picked two out of it.
