465 shifter removal question
Discussion in 'The Garage' started by big_truxx, May 1, 2005.
  1. big_truxx
    big_truxx 1/2 ton status
    Oct 8, 2004
    2,272
    Canaan, Maine
    How do you remove just the shifter from the 465? Is it possible w/ the cab on?
  2. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Put the trans in neutral first. The collar around the bottom of the shifter, press it down and turn counterclockwise then simply lift it straight up
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    pair of decent size pliers work great, bite the dome top deal around base of the shifter in tp of tranny, it is sheetmetal pressed dome shaped part, it sits in top of tranny case by two roll pins in from three and nine o clock postions when lookinf straight down at top of tranny
    push down on thye dome while gripping the dome with plier jaws and turn it counter clocwise it is "spring" loaded upwards to stay hooked on the roll pins
    youll see how and why once you get it undone
    its real easy and basic once you get it
    and neutral is best position for removal yep
    it will come right out and it is pretty short end of stick inside there
  4. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    :yikes: so simple a 5 yr old child can do it... get me a 5 yr old child!!! :haha: :D
    Thanks brothers!! ;) :waytogo: will make lifting cabs off, changing transmissions etc etc a lot easier for me in the future :D
  5. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Works good for putting fluid in it also...
    Yeah, I'm lazy.
  6. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    thats a very handy trick too :D
