465 swap ???
Discussion in 'The Garage' started by clarkjw24, Nov 6, 2005.
  1. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    McBee, SC 29101
    I'm putting in a sm465 and need to know what all I need to take from the donor vehicle. I've got the vehicle and I think I ready to send it to scrap but was just wondering if I'm forgetting anything. Will the pedal assembly bolt in to my existing under the dash brackets?
  2. Tominator II
    Tominator II 1/2 ton status
    Nov 5, 2005
    South Park CO 80440
    I had a 75 donor truck when I put a 465 in my 73 and the clutch pedal bolted right in. The under dash spring was real fun to install as I recall. Get all the clutch linkage,brackets,springs,etc off the frame. Pull everything you think you could possibly need and you'll be fine.
  3. diesel4me
    Jul 24, 2003
    I'd keep everything..
    I think youll need the whole cluster AND the pedals,not sure--I did when I put an SM465 in my 72 K5,the automatic pedals were different,I could not just "add" the clutch pedal alone onto the brackets. Save all the linkage,etc,even if you dont plan to use it..someone else might need it!..
    I'd keep the donor truck until the swap is done if at all possible..its embarassing to have to go back to the junkyard,and get parts off the same truck you junked there --IF its still there that is!--(I've done it myself!--and a few times they didn't just say "take it"..they charged me for it! :blush:
    Now when I junk something,I take everything that unbolts off,and save it..I figure I can always toss away what I dont use or sell it to someone who can--better than buying it back from the boneyard! :doah: I send them only a rusty shell when I'm done stripping it!.. ;)
    Its easy to forget little trinkets you'll need,that are hard to get at dealers,and can sometimes not be had at all,except for off a used hulk..like moulding clips,chrome trim strips,emblems,door handles,vent windows,etc..--its so nice to have a parts truck in the backyard--its like having your own personal junkyard,and all the parts are free! :laugh:
  4. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    Fort McMurray, Alberta
    Make sure you get the z-bar bracket that is riveted to the frame, you'll be needing that later!
    I'd highly suggest going hydro, its easier to install on a truck you are converting :)
