465 Swap
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Skroo, Dec 11, 2002.
  1. Skroo
    Skroo 1/2 ton status
    Jul 13, 2002
    137
    Houston, Texas
    I just spent the last 2 nights(5:30 to 2:30) swaping in a 465 under my Blazer. We got everything bolted up and started her up. I tried to move it and the clutch wouldn't disengage. The linkage(mechanical) is adjusted all the way out but it still isn't far enough.
    It is a 465/208 combo with mechanical linkage. I used what I was told is a 1982 pick-up for the pedals and linkages and flywheel. Could there be some differance between the trans and the linkages?
  2. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    um...what kinda clutch did you use? Did you install the clutch disc correctly? maybe the wron pivot ball or shift fork?
    Chris
  3. Skroo
    Jul 13, 2002
    137
    Houston, Texas
    I used a new clutch from orielly and it's installed right. I'm gonna pull it back tomorrow and put the fork from the parts truck on.
  4. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I know that when Krazie87K5 swapper to a 465, he had some problems with differnt styles of shift forks...Hope it work out for you...
    Chris
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    81 was last year for 73-on style of crossmember and some other thingd, donor truck of 72-81 or 82-up needs ot be found depending on year of truck youre converting
  6. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    i ran into the simailar problem when i bought a new brute force clutch. it seemed that the friction disc was larger than the bolt pattern would allow, after giving it a bit of gas while lightly pressing the break it broke loose. i also have had problems with the aftermarket shift forks, they seem to be the wrong shape and do not seat on the pivot ball correctly. just my $.02
  7. BTCRAWFORD
    BTCRAWFORD Registered Member
    Nov 20, 2002
    17
    PHOENIX, ARIZONA
    Make sure you have the right length throw-out bearing also
    as well as the length of fork!
  8. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    There is a "length" difference (relative to how fork pushes on the clutch) between a hydraulic clutch fork and manual clutch.
    See my sig. I had the description wrong when I first posted these pics, now the description is right.
    Good luck.
  9. Skroo
    Jul 13, 2002
    137
    Houston, Texas
    I won't get to change it out until Sunday so I'll let ya'll know. Thanks!
