472 vs. 500...Opinions needed
Discussion in 'The Garage' started by dhdescender, Jul 16, 2003.
  1. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    I've been offered a Caddy 500 with R/B heads (for propane) for 300cdn (about 200usd), good running engine. I can easily aquire a BOPC turbo 400 and swap tailshafts. I wanted to do auto, but drilling the crank and balancing a flywheel turned me off.
    In all my searches through coloradok5, 500cid.com etc, it seems the 472 is a slighty better engine due to better mileage, and torque curve. I havent had any decent luck finding a good running 472 built for propane, however.
    How much 'worse' will the 500 be compared to the 472? It's not as if I NEED the extra cubes or horses, but will I regret the 500 over the 472? I know I'll never get 20mpg out of the pigs, but I've heard 15 on the highway is reasonable even with 38's.
    Thanks in advance for your input. /forums/images/graemlins/k5.gif
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    tell me how your getting 15 MPG outta your big block motors. I'm getting 8 with a mild SBC 350
  3. eldon519
    eldon519 1/2 ton status
    May 27, 2002
    161
    Kennesaw, Georgia
    Caddies have the potential to get better mileage than most other big blocks or even many small blocks.
  4. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    I have heard the 500 was the better motor. I have seen enough good things on those motors that would make me try it out if the right deal came along....
  5. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    you can't go throwing those statements around without some reasons or examples:
    My rig will out wheel any tube buggy around
  6. 45acp
    45acp 1/2 ton status
    Jan 3, 2001
    695
    Tucson, Arizona
    The cad500/472 was built to develope very large torque in the low RPM range much like a diesel and can pull much taller gear ratios without loss of power. The big heavy 70s cadillacs were no slouch at pulling away from a stop sign. Thats way they make such a good truck engine. Loooong stroke!
  7. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    There are several people getting what we would call outstanding mileage from their Caddy motors....some of them are even members here....
    An engine gets the best mileage running at it's torque peek, and those motors make their torque at a much lower RPM than any Chevy ever thought of. It all has to do with the bore/stroke ratio....
  8. IronMan
    IronMan 1/2 ton status
    Nov 16, 2002
    223
    Bay Area, CA
    You don't have to rev the engine above 1,800 rpm to get your rig moving. Its making all its power below 2,200 rpm. Basically you dont have to give it much gas, so its not burning as much gas. I have a 500 cad for sale, all new parts. /forums/images/graemlins/deal.gif
  9. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    427 is a high revving big block, the 500 is expensive to rebuild and the heads probably suck flow wise since its really old.
  10. eldon519
    May 27, 2002
    161
    Kennesaw, Georgia
    Sorry man, I don't know the reasoning behind it. I just know it from talking to people about them. /forums/images/graemlins/crazy.gif
  11. dhdescender
    Aug 10, 2002
    628
    427? Dislexia? Did Caddy ever do a 427?
  12. IronMan
    Nov 16, 2002
    223
    Bay Area, CA
    The cost to rebuild a caddy engine is only marginally more that a BB Chevy. And I think your getting a better quality engine for the money. Weight of a SB Chevy, better mileage, more horsepower, and a torque monster engine with a tabletop torque curve. The quality of the castings, and the way the assembled them is far superior to any other Big Block. All pieces were temperature stabilized and checked for clearances before being assembled. If you were to bore a 500 .030 over and up the compression, along with some head work, and other tweaks here and there, It would produce 500ft of torque idiling! /forums/images/graemlins/eek.gif
  13. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    I really wish you were closer. We're looking for a good engine like that for our motor home.
