480le swap
Discussion in 'The Garage' started by HELLBENT DESIGNS, Jun 21, 2005.
  1. HELLBENT DESIGNS
    HELLBENT DESIGNS 1/2 ton status
    Apr 2, 2005
    453
    bozeman mt
    a buddy of mine is building a rat rod. he has a chance to get a 2wd 480le for $300. question is does anyone offer a kit to work with a non computer rig? i told him a 700r4 might be a better choice if the swap kit is too many$$$$$ :dunno:
  2. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    Try TransGo, I believe they offer kits to run it in a non-comp application.
  3. tx_sub
    tx_sub 1/2 ton status
    Mar 5, 2004
    548
    Denton, TEXAS
    tci makes one. 659.99 in jegs
  4. tx_sub
    Mar 5, 2004
    548
    Denton, TEXAS
  5. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Or look for a factory diesel truck with a non-computer controlled 6.2/6.5L and the 4L80E. You can get the stand alone transmission computer out of that model (1991 is a good year for them) along with the wiring.
  6. BAJA_BLAZER
    BAJA_BLAZER 1/2 ton status Author
    May 17, 2001
    517
    San Diego, CA
    Actualy TransGo makes a Full Manual Kit for the 4L80E that is about $250.00 and there are about seven different aftermarket computers available $800 to $1200. I think the best are the CompuShift ($1200) and the TCI ($900) and I would stay away from the Jet unit. I have a TCI that I would sell.
  7. HELLBENT DESIGNS
    Apr 2, 2005
    453
    bozeman mt
    he did mention it was from a diesel :thinking:
  8. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,921
    331
    Fort McMurray, Alberta
    The newer computer controlled diesels will have the controller intergrated into the engine computer.
    He'll need to have the diesel controller re-programmed for a gasoline engine, or it'll shift like it was a diesel engine.
  9. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    you need 4 things to run it. tps signal , map signal , raw rpm signal, and coolent temp signal. these will tell it how much load is on the motor and also also give it points of mesure to shift by. hope this helps. if he was doing a tbi motor setup you can get a tbi 4l80 standalone harness for 400 from www.howell-efi.com hope this helps.
