496/SM465 OR 496/400
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by 496 blazer, Dec 30, 2001.
  1. 496 blazer
    496 blazer Registered Member
    Sep 9, 2001
    21
    Newark, California
    IM PUTTING A 496 BB IN MY 70 BLAZER AND JUST WANTED TO KNOW WHICH IS A BETTER COMBINATION TURBO 400 OR SM465 BOTH W ITH NP205. THANKS RICK
  2. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    Both are good choices. For street driving, the TH400 kicks the SM465's butt. The 465 is a prehistoric, cantankerous transmission and shifts like it. If you're set on going with a manual tranny, run to get a New Venture 4500 5-speed. Shifts slick as heck and can be had with synchronizers in all gears (including reverse).
  3. Ryan B.
    Jul 18, 2001
    5,693
    CA
    I'd say that Steve is right again.
    I second everthing he said.[​IMG]
    [Real Men Don't Care About Gas Milage Or Rapid Tire Wear!]
    Ryan B.
  4. tshiko
    tshiko Registered Member
    Apr 13, 2001
    26
    I agree with the guys, and I would recommend you stick with the TH400 if you don't want to upgrade the axles to 3/4 ton's. The 496 will kill your differentials pretty fast if you use a manual transmisssion.
  5. 71with42s
    71with42s Newbie
    Nov 21, 2001
    bay area
    I put a 396 in my 71 and I have an sm 465 but i cant fit any exhast on the left side because of the z-bar so if you are going with the manual trans probibly better with hydrolic clutch any questions 408-255-7047 kayvon
    <P ID="edit"><FONT class="small">Edited by 71with42s on 01/08/02 10:57 PM.</FONT></P>
  6. Zepplin
    Zepplin 1/2 ton status
    Aug 29, 2000
    920
    Bay City, MI 48706
    What's the spec's of the engine; what kind of heads, intake, cam, piston manfacturer, carb.
    I have a 496 short block and I am still shopping around for
    heads and an intake. Did you go with oval port or rectangular port heads?
    74 Blazer
    Zepplin
    Check out my Blazer
    <a target="_blank" href=http://community.webshots.com/user/zepplin1976>http://community.webshots.com/user/zepplin1976</a>
  7. 496 blazer
    Sep 9, 2001
    21
    Newark, California
    im using victor cnc rectangularport 345cc. I have a bill mitihell 496 stroker kit. crane came 636./636.lift. And the carb is a 1050dominator by holley. 700flbs of torque and 750 hp these are the dyno numbers.
    later rick
