4bt in a 1978 Blazer
Discussion in 'The Garage' started by crawlink5, Apr 20, 2006.
  1. crawlink5
    crawlink5 1/2 ton status
    Oct 9, 2003
    431
    Spring, TX
    1978 Chevy Blazer - Bonanza Edition
    1986 Cummins 4BT rebuilt
    4 wd NV4500 rebuilt from GearTechHD.com
    w/hyd clutch
    NV to 465 bellhousing with no adapter - machined at GearTechHD.com
    11" clutch and pressure plate for BB chevy
    Flywheel from Avant Salvage
    pilot bearing
    np205 rebuilt from GearTechHD.com - twin stick
    NP to NV with no adapter - machined at GearTechHD.com
    14bff rear 4.56 detroit with disc brakes
    d60 front 4.56 open
    Hydro boost from 1985 Blazer w/diesel
    a 1" inch body lift would be nice but not absolutely necessary. A 5.5" spring lift in front and a 4.5" shackle flip in rear. the lift is necessary due to height of motor. No hood cutting but it is about 1/2" from hood.
    26+ mpg highway
  2. sweetk30
    Nov 1, 2004
    25,546
    542
    horseheads , ny 14845
    and your point is what?:confused:
    no pics of links to see it. sounds good with the specs but we want pics. :mad:
  3. crawlink5
    Oct 9, 2003
    431
    Spring, TX
  4. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Why not a 12"? Fits on the same flywheel as the 11". Unless the clutch size is restricted somehow by the engine or starter. :thinking:
  5. crawlink5
    Oct 9, 2003
    431
    Spring, TX
    I am pulling it out this coming weekend - so I'll have to remeasure. Maybe it is a 12. But, I didn't know the 12 would fit same as an 11.
  6. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    MIGHT fit...
    Some of the cast aluminum bellhousings with no inspection cover wont fit over a 12" clutch pressure plate..:doah:
    Not the end of the world though..an 11" clutch has nearly the same surface area as a 12" does...even a 10-1/2" disc has more area than you think..its lining goes closer to the center than any of the other sizes..
    I ran 3 12" clutches in my 72 K5 ,and all 3 of them failed in short order..the 3 finger pressure plates all lost one finger,and they would no longer release!:doah:
    ..I finally got sick of pulling the SM465 and NP205 out ,and used a diaphram style 11" centerforce clutch my friend gave me from his drag car that got totaled after only 4 runs down the 1/4 mile..never gave me a lick of trouble,and my left leg quickly shrank back to its normal size..:p: --those 3 finger 12" pressure plates sure had a high pedal effort..:crazy:
  7. u2slow
    May 9, 2001
    2,217
    BC Canada
    If its a truck bellhousing (5.125" index, i.e. for SM465), and a 168-tooth flywheel, either the 11" or 12" can be used.
    I've used the 11" on L6's, and 12" on the V8s - all were diaphragm type.
    I haven't measured to calculate the actual surface area, but the 12" comes with the larger engines and higher GVWRs.
  8. Brians89K5
    Brians89K5 1/2 ton status
    Jan 4, 2006
    535
    Rialto Ca.
    This is exactly what I want to do with my truck when my 350 finally craps out. Although I was thinking of using a newer cummon's from a 1 ton truck. I just gotta figure out how to get CA smog to allow me to do it on my 89. :-(Badass my friend. I am quite jealous!
    ~Brian
  9. crawlink5
    Oct 9, 2003
    431
    Spring, TX
    That is the bellhousing I have. No inspection cover. But IIRC, looking at the pressure olate I don't think it could have gotten any bigger. I never measured it - I just assumed 11"
