4bt swap need trans info
Discussion in '1982-Present GM Diesel' started by crawlink5, Sep 17, 2005.
  1. crawlink5
    crawlink5 1/2 ton status
    Oct 9, 2003
    431
    Spring, TX
    Question - with the stock 10 degree adapter on the 4bt and the chevy bellhousing, do I need the chevy input on the nv4500 ot the dodge? Which pilot bearing do I need?
    Here's what I'm still missing:
    -Chevy NV4500 4x4 trans
    -np205 32 spline off of a th400. Passenger drop.
    -flywheel for a manual trans for a 4bt. Where to buy?
    -bellhousing for the nv4500 to the 4bt. I'm putting the 4bt in at a 10% lean with the adapter thats on it. That said I need the chevy bellhousing - I think. Doner vehicle?
    -brake hydraboost for a 78 Chevy Blazer. Doner vehicle?
    -hydralic clutch pedal down to the slave cylinder for the bellhousing for the nv4500. Doner vehicle?
    -clutch, pressure plate 13", throwout bearing, and pilot bearing for the above.
    I have a place to get a rebuilt nv4500 and the clutch, etc.
    Thanks for any info you can give.
