4High not working
Discussion in 'The Garage' started by outsider223, Oct 1, 2002.
  1. outsider223
    outsider223 1/2 ton status
    Mar 17, 2002
    122
    Green Bay, WI
    I finally got my new tires yesterday, 33" BFG All-Terrains. Decided to see what they could go through, and realized that my 4 high doesn't seem to be working. I have a NP203 x-case with the stock auto hubs. Is there an easy way to test to see if 4 high is really gone? Thanks.
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    put it in 4hi and have someone look under the truck and see if the front driveline is turning if it is its the crappy auto hubs /forums/images/icons/frown.gif
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    An NP203 is always in 4WD unless it's been coverted to part time operation. The 203 also never came with "auto hubs". The axles were always connected to the wheels. Did someone convert your 203 to part time and then install a set of factory auto hubs from a later model truck?
  4. outsider223
    Mar 17, 2002
    122
    Green Bay, WI
    Took a good look at the blazer with a friend this afternoon. The front driveshaft turns with 4 high, but the front wheels don't want to turn. Although in 4 low, the front wheels turn just fine. So, it must be that the hubs are crap /forums/images/graemlins/frown.gif Thanks
  5. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    I would say in that case it would be something wrong with the transfer case.
  6. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    If the front wheels pull just fine in 4-Lo, then the hubs are working. And if the hubs are locked, then the front driveshaft will turn, even in 2WD. Sounds like your transfer case isn't shifting into 4-high. Have you done a body lift recently or made any other mods? Perhpas the shifter is hitting the hole in the body before it puts the case into 4-high.
  7. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    It more then likly is the linkage.. I just went through this with mine... Best thing to do is go buy a chiltons.. 203 are the only T-case that has adjustable linkage and they need to be adjusted. When you do some work on the truck.. It is a pain to adjust also.. If you don't want to go buy a chiltons PM me.. I will scan that part for you..Dan /forums/images/graemlins/thumb.gif
  8. outsider223
    Mar 17, 2002
    122
    Green Bay, WI
    I dropped the transfer case 1" when I put my suspension lift in a couple of months ago. But thats the only change that would affect the transfer case.
  9. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    That will affect the linkage.. That is the problem.. Those things have to be set just right. And moving the T-case will do it..Dan /forums/images/graemlins/thumb.gif
  10. outsider223
    Mar 17, 2002
    122
    Green Bay, WI
    Thanks, that would have taken me a long time to figure out myself. Just curious, if the linkage is wrong, which causes 4 high to not work, how does 4 low still work?
  11. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    It is in the shifter.. Mine wouldn't go in to 4 high also.. If you follow the lingage back to where it goes into the T-case.. When it is in nuetral both of those have to be straight up and down.. The one on the outside is for high/low the inside one is for 4x4.. On the shifter itself.. Put that in nuetral and you will see a small hole on the side.. Put a nail or a 11/64 drill bit throught it.. That is true nuetral.. Then look at the linkage.. If it is off even 1/8 of inch that will cause the problem.. You have to adjust it so they are straight up and down.. You will probaly have to drop the front of the drive shaft to get to it.. I just did this last weekend and Grim Reaper and Chiltons taught me.. Have fun.. Like I said if you want PM me and I will scan the instuctions for you..Dan /forums/images/graemlins/k5.gif
  12. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    I just read you profile.. It says you have a 87 K5.. You sure you have np203 t-case.You should have a NP208 in it. If so then disregard all that about the linkage on the NP 203. /forums/images/graemlins/confused.gif
  13. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Aha! The 208 has the shifter afixed to the floor of the truck, so lowering the t-case would mess up the linkage for sure, as it alters the distance from the shifter to the t-case. Just make the linkage from the shifter to the t-case a tad longer and all should be well. /forums/images/graemlins/cool.gif
  14. outsider223
    Mar 17, 2002
    122
    Green Bay, WI
    I honestly don't know for sure what transfer case is in it. So i had some guys at our school's club look at it. They said it looked like a NP208. Does this tranfer case still have an adjustable linkage?
  15. rebelk5frk
    rebelk5frk 1/2 ton status
    Dec 29, 2001
    815
    Houston, TX
    Yes the 208 has adjustable linkage.
  16. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Yes but it is diffrent then the 203..
