4in lift springs
Discussion in 'The Garage' started by CHEVY 4WD, Oct 26, 2002.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    If you get a skyjackers 4in lift with ALL SPRINGS and no blocks. Are the just arched more or is there somthing differnt? When they get worn will they bacially be like having no lift on saggy stock springs?.
  2. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    they are arched more than stock springs..and after time they will sag a little but never enough to back down to stock height!! they will just sag a little and you will notice after they get "broke in" its not quite as tall..but it wont sag that much.
  3. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    Do you think it will drop a inch or more?
    if so then Zero rate could fix that right
  4. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    hmm im not sure...possibly but no more than that..but i dont think so..cause usually when you put them on they are an inch or so higher than what they say..and they settle down to what they say...like say 4' after they get broken in..but if you had a saggy but or something then yea zero rates could fix that...
  5. bigjbear
    Feb 18, 2000
    13,971
    451
    Marietta GA
    I put 4" Skyjacker springs all around on mine a few years ago. While I know they have settled a little, they raised the truck 5.5" when I first put them on. I am very pleased w/ them.
