4in Rough Country Lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Chaz316, Nov 15, 2001.
  1. Chaz316
    Chaz316 1/2 ton status
    Jul 25, 2001
    224
    Georgia
    I have contacted Rough Country on several occasions trying to find a reason for the front end "death wobble". I have still found no answer. Does anyone have any ideas?
    "If it aint broke don't fix it" is like a 4 letter word.
    <a target="_blank" href=http://www.phatboy.alloffroad.com>PhatBoy.AllOffRoad.com </a>
  2. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    What exactly is "death wobble?
    <font color=purple>//////
    <a target="_blank" href=http://blazer79.freeyellow.com>blazer79.freeyellow.com</a></font color=purple><font color=black>
    Soon a 454 K5!!</font color=black>
  3. 86blazerk5
    86blazerk5 1/2 ton status
    Aug 9, 2000
    387
    Hagarstown, Maryland
    I have a 4 inch Rough Country lift, and do not experiance a "death wobble". Waht exactly are you talking about?
    ike
    Spreading The K5 Gospel!
  4. Chaz316
    Jul 25, 2001
    224
    Georgia
    Something in the front end is not right. If I hit a bump with the left front tire the front end bounces back and forth violently until I almost completely stop.
    I installed the lift on flat ground with the weight of the vehicle on the spring when I torqued them down. Shocks are right everything is cool. Has anyone had to install a sway bar lowering kit with a 4in lift? I have installed probably 6-8 of these 73-87 lifts but this is the first Rough Country.
  5. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    i have a simular problem but i have Mystree leafs and it started after the D60 swap
    -Zakk
    '77 K5 SB 400 TH350 NP203 p/t 6" Lift D60 14BFF 4.10's 36"Wrangler II's
    [​IMG] CK5's MOAB 2002 OR BUST!! [​IMG]
  6. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    What do you have for steering stabalizers?
    Ken H.
    '85 K5 in process
  7. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    I agree here, most likely a stabilizer problem. That is the most obvious thing that causes the death wobble, but it may just be magnifying bad front end parts. Id say change the stabilizer if its not very new and check the front end parts ( tie rod ends, etc&gt;) real good.
    82 K5, 6.2L Diesel, sm465, np205, 14 bolt welded, 8 lug 10 bolt lock right, 410 gears, 35" Mud Kings
    SPEAK SOFTLY AND DRIVE A BIG TRUCK
  8. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    chaz. i had this EXACT problem when i got home from tellico. the city had ripped all the asphalt from the street which left the man holes about 4" above the surface. everytime i hit one i got the death wobble you describe. i put my swampers on a few days later, and even on a semi-smooth street, it would do the same thing. out of no where SS--hh--aa--kk--ee-----ww--oo--bbb--llee---.
    after a little inspection, i found that the tellico rocks bent my tierod at the adjusting sleeve which in turn toed-in the tores which would make them "fight" each other and cause the shaking. a new tie rod solved my problems.
    bottom line--INSPECT THE TIERODS!!! Let us know what you find out, because i too have a rough country lift.
    good luck rob
    350 TBI, 700R-4, NP241, D44-14FF, 4:10's, 38.5 TSL/SX's, full conv., full cage
    <a target="_blank" href=http://www.yeild2me.rockcrawler.com>www.yeild2me.rockcrawler.com</a>
  9. Chaz316
    Jul 25, 2001
    224
    Georgia
    I am using the factory stabilizer.
  10. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I have a RC 4" lift and haven't experienced anything like this. I run dual Heckethorn steering stabilizers and have an ORD steering brace installed.
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
  11. yeild2me
    Jan 7, 2001
    1,309
    fayetteville, nc
    i have a single rancho stabilizer, factory sway bar w/disconnets, and the sterring brace. i thought it was going to do it again today, but it didnt.
    WTF??
    chaz, maybe i should get ahold of rough country too??
  12. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    I installed this setup in mine and no problems. What size tires are you running?
    1984 K-5
    4" lift
    35x12.5 MTs
    buildin a 400 for it, any info greatly appreciated
