4inch lift, and the usual problems.........
Discussion in 'The Garage' started by Jeremy_C, Jul 29, 2002.
  1. Jeremy_C
    Jeremy_C 1/2 ton status
    Mar 26, 2002
    1,381
    East TN
    Hey all, i've got a 78 chevrolet 350 auto with a 4inch super lift suspension lift. I just threw a driveshaft again. Do I need a longer driveshaft? I already know that i need to tilt the rear-end up some, but do I also need a longer driveshaft? And if I do, does anybody have one for sale /forums/images/icons/laugh.gif
    Also, I need a cheaper way to tilt the rear end, what have you done thats worked? /forums/images/icons/smirk.gif
  2. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    What exactly do you mean by "threw a driveshaft"? Front or rear? /forums/images/icons/confused.gif
  3. Jeremy_C
    Mar 26, 2002
    1,381
    East TN
    Oh yea....sorry bout that
    It was the rear driveshaft, it didn't start shaking or anything....It just hit the ground as i was going down the road about 50mph /forums/images/icons/frown.gif
  4. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    What t-case do you have? Did it seperate at the t-case or the pinion? Did the shaft actually pull apart or did a u-joint break? Sorry for the rapid fire questions, just tryin to get an idea about what happened. /forums/images/icons/grin.gif
  5. Jeremy_C
    Mar 26, 2002
    1,381
    East TN
    hey no problem on the rapid fire questions, thats fine with me. The u-joint busted i guess, the drive shaft fell out of the tail shaft, and the drive shaft hit the ground. I've not found the tail shaft yet, i'll have to go look at day light.
    Not sure on the T-Case /forums/images/icons/confused.gif
  6. jc71355
    jc71355 1/2 ton status
    Jan 13, 2002
    830
    Port Neches, Texas
    Dropping the T-case will probably help your situation.
  7. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Some people here are running 6" lift with the stock drivelines,and some people needed to extend there driveshafts just for a 3" lift (like me) Every truck is different. It's hard to tell.. /forums/images/icons/smirk.gif
  8. Brownjoe
    Brownjoe Registered Member
    Jul 11, 2002
    38
    Sacramento Ca.
    I had my truck lifted and stated to bleed from the rear main seal, but since having my driveshaft extended the bleading stoped, I just hope it dont put added stress on the spoines. /forums/images/icons/smile.gif Happy trails.
  9. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Easiest thing to do (and probably one of the cheapest) is to re-install the existing driveshaft, then make a mark on the slipjoint where the two parts currently come together.
    Bring the driveshaft to a local driveshaft shop....they can look at where the mark is, and then they can probably lengthen and re-balance the existing shaft if that's all that's wrong.
    The only other concern though, is if you haven't dealt with pinion angles, you may be running those u-joints at an excessive angle which dramatically reduces their lifespan....if you keep breaking u-joints (even on the street), then you will probably have to cut-and-turn your spring perches, or at least add angle shims to the springpack to reduce those angles.....
    Just a few ideas. /forums/images/icons/smile.gif
  10. Jeremy_C
    Mar 26, 2002
    1,381
    East TN
    The shim idea is probably what i am going to do. Do i need a machine shop to make one, or do they actually sell them some where?? /forums/images/icons/smirk.gif
  11. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Most spring manufacturers will sell various degrees of shims...Superlift comes to mind, but I'm sure there are others....
  12. tRustyK5
    Jul 23, 2000
    36,181
    1,388
    E-town baby!
    I've found 2*, 3* and 4* shims available at a local spring shop. It's not a custom 4x4 shop either...so I'd guess any spring shop should carry them in stock.
    Rene
  13. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    do shims make the center spring bolt move out of the perch hole? just wondering?
    nathan
  14. tRustyK5
    Jul 23, 2000
    36,181
    1,388
    E-town baby!
    Yeah they do, but the same place sells the small spacer washers that should be used with shims to keep the center bolt far enough into the perch...
    Rene
  15. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    I have busted 3 driveshafts with my 4 inch lift. I got no angle in the rear because of angled blocks. I just put in a driveshaft loop, and carry around an extra u-joint /forums/images/icons/tongue.gif
  16. 94JeepYJ
    94JeepYJ Registered Member
    Jul 30, 2002
    6
    Rochester N.Y
    Yes, he's right if you drop the Transfer case a few inches the driveshaft will be at less of an angle so you wouldn't break the driveshaft. And getting spacers for the T-Case is cheap!
  17. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    how do you get the transfer case dropped. do you just lower the crossmember and let it pivot down?
    nathan
  18. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    Yep, just take the existing spacers and move them above the cross member. Worked great on my lift.
  19. Jeremy_C
    Mar 26, 2002
    1,381
    East TN
    I lost my tail shaft, so I'm gonna have to get another one. I think my transmission got a hole knocked in it, it was leaking pretty bad. Would the tail shaft have anything to do with it leaking so bad?? /forums/images/icons/confused.gif
  20. 94JeepYJ
    Jul 30, 2002
    6
    Rochester N.Y
    Yes it would, but also there are, i think 2 hoses from the transmission to the radiator and you could have punctured one of those.
