4l60 shift problem - need advice
Discussion in 'The Garage' started by Rolled, Apr 30, 2007.
  1. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    I have a 4l60 that will not shift in drive or overdrive.
    It will shift gears if I manually shift them. Just not on its own...
    What could that be?
    I just bought the truck so I don't know the history on it.
  2. pin_it_to_win_it
    pin_it_to_win_it Registered Member
    Jun 21, 2006
    94
    centeral coast california
    Sounds like what happened to a frend of mines beater truck he was reving it out in nutral and shifting in to drive to get the holeshot when he tried to race people on pavement:haha: . tranny needs rebuilt:doah:
  3. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    TV cable set ok? Level ok? Have you serviced the trans? Is the linkage actually pushing the selector through D and OD?
  4. Rolled
    Jun 16, 2002
    683
    Anchorage, Alaska
    Its a 1995 4l60E, BTW. I forgot to mention it was electronic.
    I just put a new filter, fluid, and gasket on when I rebuilt the motor. I never drove the rig before I did the motor. Motor was blown when I bought it.
    No TV (I think) cause its electronic. I goes ito all gears via the shifter.
    It just won't shift by itself.
    Does anybody have a link to a diagnostic chart for these? I'd like to start narrowing down the problem before I yank it out.
  5. SkysTheLimit
    SkysTheLimit 1/2 ton status
    May 23, 2003
    530
    Tampa, FL
    I don't know how to tell but is it a manual valve body?
  6. BoondocK5
    BoondocK5 1 ton status Author
    May 13, 2006
    10,035
    63
    Salt Lake City, Utah
    I have the complete rebuild instructions and diagrams but if you've never done one, I would not suggest doing it
  7. Rolled
    Jun 16, 2002
    683
    Anchorage, Alaska
    I would like any info you may have. You can email me at
    gorathcredits @ yahoo.com
    I have rebuilt th400. Never a 700r4/4l60
    I am oping I can trouble shoot it and fix it instead of rebuild it. Its electronically shifted so it may be a simple servo replacement. I just don't know much about these trans and would really like to find an online bible to diagnosing them. I figured CK5 was the first place to start since the wealth of knowledge here is unprecedented.
    This is in a 1995 Jimmy, BTW.
  8. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Well that changes my answer a bit then! I'll have a dig around for info but I've not messed with those.
  9. Rolled
    Jun 16, 2002
    683
    Anchorage, Alaska
    I think I found the problem. I have not fixed it yet but feel pretty good about it.
    I think its the VSS. Ma speedo does not work and the ABS light is on. I found a few references to my upshift problem that indicates the VSS is to blame... Its an easy fix so I'll try that out later on.
    Here is a good diagnostic chart I found. Maybe somebody can use it in the future...
    Here is the link to it incase it goes dead.
    http://impalassforum.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=4;t=006666;p=
  10. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Awesome... been reading around, I'm having the
    " 11. No 1st or 4th available; trans shifts 2nd to 3rd by itself in D or OD : ShiftA solenoid failed. Easy fix in the pan. Or a wiring problem from PCM to trans.. or PCM."
    issue currently. Planning on calling around tomorrow for the shiftA solenoid, not looking forward to dropping the exhaust to get to my trans pan though... :doah:
  11. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Pan dropped out without removing anything more than the t-case skid plate (ZR2). Had to do some research the Shift Solenoid A and Solenoid B are the same type. The one on the drivers side is A and the passengers side is B. I only replaced A. Having do it again I might opt for a shift kit. I done a couple searches to find out which Solenoid was which and there is a ton of sites for upgrade parts and performance parts that are basically the same price as dealer items. I called three places on prices, $41 (local dealer), $30 (local Napa), $23 (dealer 20 miles away). Never hurts to call around!
    Trucks seems to run normal again!
