4L60 whinning
Discussion in 'The Garage' started by 83suburbman, Nov 7, 2005.
  1. 83suburbman
    83suburbman Registered Member
    Oct 4, 2005
    13
    Vancouver WA
    My dad's (97 chevy) tranny whines like crazy. But only when you put it in gear and then the sound kind of changes gears with the trans then it go's away when it hit's overdrive. (what's up anybody know?)
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    probably a bad sprag somewhere. Different ones engage and disengage with different gears(could be one that engages through the first three gears and not in overdrive). Someone should know better then me, I've had one apart but can't remember the internals or whats locked in what gears.
  3. XHitman396
    XHitman396 1/2 ton status
    May 3, 2002
    620
    Broken Arrow, Oklahoma
    kinda hard to troubleshoot a sound when you're going off what someone is typing about, and are you positive it's the tranny??
  4. diesel4me
    Jul 24, 2003
    17,540
    926
    Massachussetts
    siren??
    If it sounds like a siren,it could be a filter thats blocked or restricted,causing the pump to cavitate(suck air,and foam up the fluid)..but it would probably slip some too if that were the case... could be pump gears too,or a bearing..:crazy:
  5. 83suburbman
    Oct 4, 2005
    13
    Vancouver WA
    that's what I told my dad ( IT"S GOTTA BE THE FILTER) its cloged and sucking from the top just like my old camaro. Well we put new filter in and no differance at all doesn't sound like a siren sounds more like a powerstering pump that's low. put in park and its gone. fluid dosent smell burnt I'am think'n pump too. thanks
