4l60e swap???
Discussion in '1936-Present Suburban' started by 88sub4x4, Aug 25, 2003.
  1. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    I am curious about swapping my 700R4 for a 4L60E is it a direct bolt in? Also what is better about the 4l60e. Is the case the same, or is it a completely different unit. Thanks
  2. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    Its electroniclly controled for one. GM changed the name from 700r4 to 4l60 in the early 90's. The e models are the newer electronic ones. I belive The the same as far as the case lenght and spline count and gear ratios. Will do some more reading into it.
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    There's no advantage gained in swapping in a 4l60e for a 700R4. If your 700 is shot, replace it with a 700. But if you want to mess with putting in an electronically controlled tranny, I'd put in a 4l80e instead of a 4l60e.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The 4L60e is a direct bolt-in, but it won't shift gears until you connect it to a computer to control line pressures, shift points, etc. I don't know what that costs for a 4L60e, but it's around $800 for a 4L80e. /forums/images/graemlins/eek.gif
  5. 88sub4x4
    Sep 22, 2002
    792
    Long Island, NY
    Thanks guys, I will just stick with the 700r4. I thought the 4l60e was just a heavyer duty unit.
