4L80 or TH400?
Discussion in 'The Garage' started by Masiony, Apr 15, 2006.
  1. Masiony
    Masiony 1/2 ton status
    Sep 2, 2005
    729
    Springfield, OR
    is there any benift of going to a 4L80 over a TH400, other than OD (or the cool factor)?
  2. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
  3. Masiony
    Sep 2, 2005
    729
    Springfield, OR
    not sure yet, but as i said, i dont want to consider OD. im looking for other reasons to run a 4L80.
  4. 1985_K5_Silverado
    Dec 21, 2005
    984
    Corn Country
    Lockup torque converter (but that's only in OD). Computer control. Again, fuel economy, and note the 3 lower gears are identical ratios. The 4L80E is a more complex piece of gear, and you know what they say about people that pay for complexity (OD, lockup TC, computer control) that they aren't going to ever use.
  5. Masiony
    Sep 2, 2005
    729
    Springfield, OR
    basically, when my 700 goes :1zhelp:, i want to figure out now what to upgrade to. but currently i am running 4.56 and 35's on pavement.
  6. Masiony
    Sep 2, 2005
    729
    Springfield, OR
    im also running 4.56 and 35's on the pavement.
  7. WRENCH-HEAD
    WRENCH-HEAD 1/2 ton status
    Dec 25, 2005
    327
    Littleton, CO
    I am running 4.56's and 35 and I have a 400 trans. I can pull about 3500 rpm on the highway, so if you can live with that then your ok. Other than that a 4l80 is just a 400 with OD. I am contemplating one for the future when I up the tire size and stuff in some 5.13s. I will only go with full manual setup with no comp or lockup converter for the complexity reasons as mentioned before. Only real benefit is the OD in that case, oh and if you go manual in a 4l80 I was told you can't get it in reverse pattern like the turbo 400. That just means a little more work shifting to 1st from reverse and makes rocking the truck interesting. Length difference is minimal, a couple of inches or so, and strengths are even except in the overdrive gear. It will take you more work to adapt it to a cast iron trans but that is the fun part and there is a good thread here on mating to a 205 if you use the search function. Cant think of much else. Basically just depends on highway time, flat highway time, OD value is debatable here in CO with the mountains.
    -ALEX
    edit: price difference, just found two HD case 400s today one with 205 t-case and one with a pass-drop 241, $50 for either setup
  8. Masiony
    Sep 2, 2005
    729
    Springfield, OR
    well, it would most likely be running a 241 doubler setup behind it. doesnt the 241 come behind the 4L80 factory?
  9. Masiony
    Sep 2, 2005
    729
    Springfield, OR
    also, whats the average price difference?
  10. WRENCH-HEAD
    Dec 25, 2005
    327
    Littleton, CO
    yes and it is a lot easier to find that adapter than the 205 adapter made in 91 only
  11. 1985_K5_Silverado
    Dec 21, 2005
    984
    Corn Country
    Here's another important TH400 vs 4L80E consideration - take a look at the price difference. It can be significant, and I saw on the transfer case thread (the one where they seem to want hurry-up-fast answers, on somewhat unusual gear, in the wee hours of the morning) that you wished you had that kind of money to throw around.
    If money is tight, the choice is pretty much obvious. If money isn't tight, then:
    What do you intend to do with the truck?
  12. WRENCH-HEAD
    Dec 25, 2005
    327
    Littleton, CO
    I have seen 4l80's from 60 to 120 around here in the cheaper yards for core and up to 500 at others. I can always find 400's for under $100 around here
  13. Masiony
    Sep 2, 2005
    729
    Springfield, OR
    the truck is an 85, running 87 TBI. is there any conflict with computer things?
  14. WRENCH-HEAD
    Dec 25, 2005
    327
    Littleton, CO
    not if you get a stand alone system from a company like TCI and such, but then you get spendy ~$800 new but you can find cheaper on ebay. Actually there is one there right now at $500
  15. Masiony
    Sep 2, 2005
    729
    Springfield, OR
    haha, you saw the other post. well the truck will be a rock basher. core price is probably what i am looking for, i can rebuild them myself. just looking for future options. got to plan ahead when you pay for tution too.
  16. Masiony
    Sep 2, 2005
    729
    Springfield, OR
    is there a non-computer controled one?
  17. WRENCH-HEAD
    Dec 25, 2005
    327
    Littleton, CO
    anything against manual valvebody??
  18. WRENCH-HEAD
    Dec 25, 2005
    327
    Littleton, CO
    in short no, only manual valvebody eliminates the comp
    edit: not sure if any convert it to vac operation
  19. Masiony
    Sep 2, 2005
    729
    Springfield, OR
    im not really familiar with the term. this is actually my first 4x4 auto.
    the rig will see highway, but only to and from the trail.
  20. WRENCH-HEAD
    Dec 25, 2005
    327
    Littleton, CO
    Used when the trans no longer shifts on its own, you shift for it. Originally a race setup now working into the 4wd world. In essence it turns the auto into a stick shift with no clutch pedal. then you would want to run a gated shifter or the likes to make sure you get the right gear.
