4L80E in a K5
Discussion in 'The Garage' started by tiger9297, Jul 28, 2006.
  1. tiger9297
    tiger9297 1/2 ton status
    Jul 23, 2004
    1,205
    Tupelo, Mississippi
    will it work?
  2. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    sure why not? its electronically controlled so youll have to firgure something out. I know a few people have taken the harness from a truck with a diesel in it because they're "stand alone" systems. I also know that theres a guy local to me that makes a controller for those trannys. Its a really nice setup, allows you to control shift points, firmness, and displays transmission temperatures on a little screen in the cab. And you can adjust all of this on the fly, its kind of expensive (somewhere between 300-600 dollars iirrc)but its well worth it if you tow alot and want some bling.
  3. K5er4Life
    Oct 16, 2002
    1,456
    Bellflower, Ca
    I dont know what you want to put it into, or what the OEM equipment is but depending upon that, you may end up with a different crossmember/location for the trans. Im not sure but I think many 4l80's had a 208 behind them, and your probably looking at some driveshaft modification.
  4. tiger9297
    Jul 23, 2004
    1,205
    Tupelo, Mississippi
    It would be going in a '90 K5. I'm about to go with a new engine and tranny. I do tow a camper alot so I thought I'd look into a stronger tranny.
  5. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
  6. 74kay5
    74kay5 1/2 ton status
    Oct 30, 2003
    486
    San Jose CA
    GO WITH A 6.0l AND A 4L80E. IT'S A MATCH MADE IN HEAVEN. TRY TO GET THE DRIVETRAIN OUT OF A 2500 01 OR NEWER.
