4L80E into blazer.
Discussion in '1982-Present GM Diesel' started by rugger03, Feb 3, 2003.
  1. rugger03
    rugger03 1/2 ton status
    May 14, 2000
    829
    around
    I "won" a 4l80 out of a 98 2500 diesel suburban today. Has anyone done this swap yet. I know i need to get the control box and harness. But what about shift linakge? I'm going to use my np208 so that will bolt right up. I know cross member has to be moved back, and drive shafts shortend/lengthend. Any thing else im missing and need to think about. Thanks, Rugger
  2. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    Shift linkage should be easy. You will need a VSS signal and a TPS signal for any controller.
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Was your NP208 mated to a TH400 or SM465? The 4L80E is 32-spline, whereas anything bolted to a TH700 or TH350 is 27-spline. Different adapter required also.
  4. rugger03
    May 14, 2000
    829
    around
    it was attached to a 400, so its a match.
  5. u2slow
    May 9, 2001
    2,217
    BC Canada
    /forums/images/graemlins/thumb.gif
