4L80E Rebuild Kit Differences
Discussion in 'The Garage' started by longbedder, Feb 13, 2011.
  1. longbedder
    longbedder 1/2 ton status Premium Member
    Oct 26, 2005
    4,020
    113
    Ridgecrest, CA
    I know there are some differences in 4L80E transmissions through the years, (like fore or aft cooling, etc.).
    Why is a rebuild kit for an early model $125 less than a kit for the late model ('97-'06)? What extra/different parts would be in the late kit?
    http://www.summitracing.com/parts/TCI-278800/
    http://www.summitracing.com/parts/TCI-278805/
    Oh, and would any of you suggest a rebuild kit other than TCI?
  2. cuervo
    cuervo Wears Boob Goggles! Premium Member
    Jan 2, 2004
    3,100
    Sweet Home Alabama!
    No clue. But I'll tell you what... that's what lets those shops get away with charging $2200 for a rebuild; it's the fact that it's all clouded in mystery and does take some training to know what is and is not needed for a trans rebuild.
  3. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    Late models had non servicable clutch apply pistons in the drums. You take the old one out, trash it, & put a new one in.
    Early 4l80's were like T-400's they had an alum piston that had seals around the outside & the inside that had to be changed.
    There are a lot of other changes but that is the one that I think would affect rebuild price.
    Are you considering building it yourself?
  4. longbedder
    Oct 26, 2005
    4,020
    113
    Ridgecrest, CA
    Yup.
  5. boz42
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    Cool. I just rebuilt mine last month. If you got any questions, just post them here. I'll keep an eye out.
  6. bailey9r
    bailey9r 1/2 ton status
    Feb 6, 2008
    300
    High Springs Fl
    ah...but you forgot to mention if it now works:haha:
    naw just kidding, I got the impression that was some complicated task, how would you rate it next to a 400 or even a 700?:dunno:
  7. boz42
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    The 4l80 is basically a 400 with OD. The lower gear unit, center support, forward & direct drums are almost identical to the 400's parts. Some of the parts will interchange. The 4l80 adds an overdrive unit, a wiring harness, & some sensors. But it lost the vacuum modulator & a govenor.
    I have never rebuilt a 700 so I can't campare it to that. IMO it is not much harder than building a 400.
    I am no trans guru. I live about an hour from a decent sized metro area, considering that you would think we would have some good trans service places, but I have yet to find one. Lack of high end rebuilders made me refuse to pay someone to build it for me when I felt I could do a good job. TCI is local but that was out of my budget.
    The hardest part about building a trans is getting good info. It takes some research & homework. ATSG manuals only go so far. A good trans builder knows tricks that can only be learned from years of experience.
  8. cuervo
    Jan 2, 2004
    3,100
    Sweet Home Alabama!
    And boy do they want you to pay for that. :eek1:
    I priced a 700r rebuild kit at under $100 bucks and the guy at the shop wanted $1200 if I took the tranny out.
    A friend of mine knew a dude that did them at home so I took it over there. He said $400 plus any hard parts that need to be changed out. I ask when would he know about the hard parts and said do you have a minute. Sure I do. That dude took the entire 700 about in less then 5 minutes then said, $400 bucks. Had it done the same day.
  9. folkenheath
    folkenheath Worthless Trash Premium Member GMOTM Winner
    Nov 12, 2004
    4,144
    54
    Wisconsin
    Call this guy
    http://www.jakesperformance.com/Home_Page.html
    I've bought from him and so has my brother, good guy to deal with. He'll sell you a kit with the right parts for your power level. And you will need the 4th clutch piston install tool. And dual feed the direct clutches too, it's pretty much free and strengthens 3rd gear almost double. Read the mods to the TH400, because many of them are the same for the 4L80E.
    Also, a lot of the upgrades for the TH400 come FROM the 4L80E. Wider front band w/ servo(for stronger manual 2nd engine braking), more abundant sprag type direct drums, thinner int pressure plate for easier installation of 4 clutches in the intermediate, etc.
  10. ZukiJohn
    ZukiJohn 1/2 ton status
    May 29, 2007
    215
    Apache jct Az
    subscribed, Will be rebuilding my 4l80e soon....
  11. DEMON44
    DEMON44 Low-Tech Redneck Premium Member
    Jan 8, 2003
    7,232
    14
    Okotoks, Alberta
    I've heard of Jakes performance. He's a regular on a huge Z-28 site that I sometimes checkout.
