4L80E stuck in 2nd gear. Why?
Discussion in 'The Garage' started by y5mgisi, Oct 3, 2009.
  1. y5mgisi
    y5mgisi 1 ton status Premium Member
    Aug 11, 2002
    17,125
    198
    Portland Oregon
    My dad has a 96 chevy one ton van. tbi 350 and a 4l80e. He says its been acting up for a while, but now he has only 2nd gear and reverse:eek1: Any ideas? I know there are solenoids in there but why would they not function properly?
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Throw a scanner on it and check the tranny codes. The computer may tell you what is wrong.
    Might have a bad shift, or pressure solenoid. like anyother electrical thing they just wear out after time. Or sometimes the screens in them get blocked with crud if the fluid is not changed regularly.
  3. sweetk30
    Nov 1, 2004
    24,890
    175
    horseheads , ny 14845
    sounds like fail safe mode. 2nd and reverse only.
    you need to find and fix the problem first.
  4. y5mgisi
    Aug 11, 2002
    17,125
    198
    Portland Oregon
    Can i use the paperclip trick to find tranny trouble codes?
  5. Keitha
    Keitha 1/2 ton status Premium Member
    Oct 13, 2008
    921
    4
    Costa Mesa, CA
    I think you can find the codes w/ the paperclip trick. Try it out.
  6. MTNMIKE
    MTNMIKE 1/2 ton status
    Jan 3, 2007
    106
    RENO, NV
    96' Is that obd1, or obd2 did you check the fluid and any connections to the tranny ?
    OBD 2 uses a scanning computer plugs in under dash on driverside. I believe obd2 came out around 96' or 97'.
    I had a friend with similar problems(not a 4l80e), he changed the fluid and filter and it worked fine (it was a newer dodge not a diesel).
    good luck!
    Mike
  7. y5mgisi
    Aug 11, 2002
    17,125
    198
    Portland Oregon
    TTT, I have heard people say this can be caused by the VSS. True? Sorry for asking these questions without having answers. He is supposed to be dropping it off at my house in the next couple weeks so i can fix it and im just trying to plan/think ahead.
  8. y5mgisi
    Aug 11, 2002
    17,125
    198
    Portland Oregon
  9. Robbie6987
    Robbie6987 1/2 ton status
    Jul 16, 2002
    111
    killeen TX
    Same thing mine did when the vss went out, big electical plug on the r/h side can work loose also and cause the same probs. Also it wont always throw a code but u can get it checked for free at autozone if u dont have a scan tool.
  10. dbabicky
    dbabicky 1/2 ton status
    Sep 17, 2005
    1,597
    Wisconsin
    1996 is OBD II
  11. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,459
    Olympia/Lacey, Washington
    wow, a year later? been driving in 2nd gear the whole time ?? :D :tongue1:
