4l80e to a 205 tcase??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Runamuck, Mar 7, 2005.
  1. Runamuck
    Runamuck Newbie
    Feb 20, 2005
    Pa
    Any one know what's invoved mating a 4L80e to a 205 transfer case (1981 tcase taken from a 400turbohydr trans)??
  2. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    i have a 2x4 fixed yoke 4l80-e that i just had a 1 1/4" alum spacer made to bolt it together. worked great.this also helps the cv head clearence problem to the tranny pan. my frt shaft clears no problem. but need to get the 4x4 oil passege plug and replace the plug with the pin hole for the solid one its about 5 dollers at dealer. and its at the 3ockl position.
  3. dyeager535
    26,975
    One way to go about it (short of what you have now) is to get a setup from a '90-91(?) pickup, since the 4L80E and 205 were mated together.
    I've got one as a matter of fact, but the output shaft and adapter are both broken. Input shaft is 32 spline and mates up to my later SM465. :)
  4. Nicks 72
    Nicks 72 Registered Member
    Feb 11, 2005
    64
    Concord California
    I remember back in 1994 I mated a 4l80e to a 205.I did this without even realizing that GM did it(like dyeager said) in 91. The 205 was from a 85 with a turbo 400. If I remember correctly I had to take about 1/2 inch off the 4l80e shaft and some slight machine work to the oring groove was done to the adapter so that the large o ring between trans and adapter could fit right. I remember calling Advance at the time and they didnt know much but I remember being concerned about cutting the shaft down and losing some spline engagement but whatever(I cant remember anymore) the remainigr length after the cut was was plenty for strength according to them. I had it in a a 85 0ne ton dually cab in chasis and It worked great.
  5. Runamuck
    Runamuck Newbie
    Feb 20, 2005
    Pa
    Thanks for the info.... 3 great responses!!
  6. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    What did you cut the shaft with?
  7. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    torch .... :D
    J/K
  8. Nicks 72
    Feb 11, 2005
    64
    Concord California
    I was too lazy to dissassemble the whole tranny to take out the shaft so I cut it while in the tranny. First I cut a piece of pipe that was about the same as the shaft. I cut this pipe just a little longer then the length I wanted my shaft to be cut at then I slipped it over the shaft. Then I cut off the shaft slowly with a chop saw flush with the pipe. Then I cleaned up the end with a grinder all the time making sure I didnt heat up the shaft too much.
