4L80E
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by James90, Oct 1, 2000.
  1. James90
    James90 1/2 ton status
    May 18, 2000
    986
    Rocky Mount NC
    Do any of you guys know any thing about this tranny it is the what they use in Humvees and I thank that it is over drive but that is all I know?
    thanks
    [​IMG]Go prepared
    I have a Shotgun a Rifle and a 4WD(K5) and Country Boy Can Survive!!!!
  2. AJMBLAZER
    AJMBLAZER Better to be lucky than good. Premium Member
    May 18, 2000
    22,792
    100
    Paducah, KY
    It's the TH400 with an overdrive. Like the TH700/4L60E is the TH350 with an overdrive. Actually, until 1993 the HUMVEE's had TH400's without Park, at 93 and later they have 4L80e's. Hope this helps.
    1992 Blazer Sport, 350 TBI, 4L60, 3" Gibson, K&N, 3" Rancho, 285/75R16 on 16x8 Baja's [​IMG]
  3. James90
    May 18, 2000
    986
    Rocky Mount NC
    Thanks Andrew
    do you thanks this would be a good tranny for a blazer with a Big Block
    [​IMG]Go prepared
  4. AJMBLAZER
    May 18, 2000
    22,792
    100
    Paducah, KY
    VERY GOOD TRANNY FOR THAT!!! Think of a TH400, just with an OD gear! Your gas mileage won't be THAT bad after all. [​IMG] Anyways, that is what Chevy/GM has put behind the 454 and diesels since 91 or so. Requires a computer, but not that hard. September's Four Wheeler details a swap into a TH400 truck. Hope this helps.
  5. River
    River 1/2 ton status
    May 8, 2000
    121
    Amstelveen, Netherlands
    AJMBLAZER do you have that article about the swap. Can you email it to me? flore@tvn.nl
    I have a 4L80E transmission (out off a `92 VAN) right here but the price off the computer stopt me from putting it in my Blazer.
    Greetings from Amsterdam,
    River `90 K5, 350, TH700R4, NP241, "33, 3.08, 10 bolt F, 10 Bolt R(GOV-Lock)
  6. AJMBLAZER
    May 18, 2000
    22,792
    100
    Paducah, KY
    Tell you what River, I'm not at home right now, but send me an email at ajm_blazer@yahoo.com, and remind me. I will send you it then.
  7. James90
    May 18, 2000
    986
    Rocky Mount NC
    is the Th700/4L60E anythinglike the TH700R4? and does it need a comp?
    [​IMG]Go prepared
  8. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    The TH700, 4L60E(4L60) and TH700R4 are all the same except I think the 4L60E is computer controlled, which is what the E means (electronic)
    90K5
  9. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    BTW the T-700 is the JET version that they added so many mods to it they just changed the name.
    90K5
  10. AJMBLAZER
    May 18, 2000
    22,792
    100
    Paducah, KY
    Tell you what (again[​IMG]), it would be a HUGE file if I scanned it, so just send me an email with your mail address over there, and I will copy and mail it to you. Won't cost more than a few bucks. Hope this helps.
  11. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    I think I recall seeing a kit to convert a 4L80E into a 4L80. It was on the net somewhere; some transmission-related site. A little searching on the net may prove me right (or wrong...)
    [​IMG] Semper Maintenance!
  12. James90
    May 18, 2000
    986
    Rocky Mount NC
    cool you thank they they make a kit to do that?! that would be grate I did not like the thot of a nouther comp!
    [​IMG]Go prepared
  13. AJMBLAZER
    May 18, 2000
    22,792
    100
    Paducah, KY
    I mailed it out to you on Friday man. Only cost me like 90 cents, don't worry about it. Later.
