4L80E-
Discussion in 'The Garage' started by crazyrc, Feb 5, 2003.
  1. crazyrc
    crazyrc 1/2 ton status
    Jan 20, 2003
    106
    Northern Alberta, Canada
    What would be the cheapest and easiest way to swap in a 4L80E tranny and case. So far it looks like I would have to buy the seperate controller. Is it true you could build one to be shifted manually. I've got a 700R4 and 208 and I know that they will not stand up to my new engine. I've thought about a T400 and 205, but I like the lower first and OD of the 4L80E. This is going into an 85. Any suggestions would be appreciated.
  2. bigbluek20
    bigbluek20 1/2 ton status
    Dec 18, 2001
    119
    Loveland, Colorado
    Some work involved... see this post:
    4l80e swap info (active thread)
    You would need to change the input shaft on your NP208 to a 32 spline from the 27 spline, add a speed sensor, computer, wiring, linkage, etc.
    As I remember, the 1st gear on the 400/4l80e is the same at about 2.5:1... your 700r4 at 3.0something:1 is actually lower.
