4L80E?
Discussion in 'The Garage' started by CHEVY 4WD, Nov 15, 2003.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Ive almost decided a 700R4 isent gonna hold up(was looing at the stage III from BTO) I THINK I really want a 4L80E, I know ill need a stand alone computer, and jet and TCI makes one but i cant find a price or any other info on them. What else is involved? It goen in to a 84 K10 (700R4/208) are there certain years or styles to look for (cant afford a BRAND new one) and can I use my NP208? one member is selling one from a 94 and has a 241 adapter but Im not sure if thats the same adapter for a 208, 1 last thing how much more does one of these weight compared to a 700R4? /forums/images/graemlins/confused.gif
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    can't help you with anything except the 208 thing. 241 and 208 are transferable adaptor wise so that one with 241 adaptor will work fine.
  3. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    IIRC that stand alone computer is like $900, not cheap or this swap would be more common....
  4. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    IIRC??? I dont see why the swap isent more popular my stange 3 700R4 i was planning on ordering(still dont have enough$$$) was about $1900 but of course thats a BRAND new trans
  5. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    Contact Ironman on this site....he had a 4L80E built by JET thats BRAND NEW, he never ran it. He was trying to sell it, he parted out his project truck it was going in.
  6. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    another question... are all 4L80E's the same? or are there certain ones that are stronger and or 2wd and 4wd or anyother models?
  7. beastk5
    beastk5 Newbie
    Jan 27, 2005
    3
    ohio
    4l80e cpu
    got summitracing.com thet have a cpu for the 4l80e for 600 bucks
    its made by tci
  8. Emmettology 101
    May 9, 2000
    8,126
    FL
    What swayed you away from the 700r4?
  9. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    you can get a full manual valve body for the 4l80-e
  10. Supergas
    Supergas 1/2 ton status
    Oct 17, 2001
    161
    Texas Coast
    :confused: Contact Hughes Performance Transmissions in Phoenix. They build that 4L80E & can answer all questions.. I don't know why everybody is blowing the 700R4 up so much. I have had one in my 71 for 3 years with no trouble plus I ran one in my 27T Supergas race car for years with no trouble... You just need to spend the money upfront for a top of the line build.
    My 2c....
    Supergas.....
  11. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    The 2wd and the 4wd have different output shafts, but I don't know the spline count.
  12. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    THey aren't. They are just more common than most other trannies in the blazers. Plus most of the grenaded trannies you read about are ones with tons of miles going out from wear and old age, or a new built motor finishing one off from a long life. The majority of built Th700's is quite rare, from my experience.
  13. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    If I am gathering right you plan on buying the stand alone computer and finding a good used 4L80E. Right?
    I highly doubt a 4L80 is any stronger than a stage 3 th700R4, infact if I had to rely on one behind big power(near the stage 3's limit) I would take the Th700R4. I think the HP rating that a stage 3 has is more than an used, stock 4L80 can handle.
  14. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Open 'em both up and take a look inside. ;) The 4L80E has larger shafts, gears, clutches, etc. The main shaft also has an extra center support to limit flex, where in the 700R4 it's only supported at each end. The 4L80E design is based on the nearly bulletproof Turbo 400. It's biggest drawback is that it has a taller first gear than the 700R4.
    I contacted Bowtie Overdrives about putting one of their built 700R4's into a 4WD Suburban, behind a mild 454 planned for towing duties in the Rockies. They recommended the 4L80E for that application. :cool1:
