4spd question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by lax037, Oct 11, 2001.
  1. lax037
    lax037 Registered Member
    May 29, 2001
    49
    Long Island
    I want to take a standard from a 77 K20 and put it in my 89 K5, my question:
    Is the flywheel going to be a direct bolt up, or do I need to get on for my year truck? any input is appreciated
  2. tRustyK5
    Jul 23, 2000
    36,170
    1,375
    E-town baby!
    You'll need a flywheel from a 87 and up sbc with the one piece rear main seal. It mounts quite differently than the older style on yer 77
    Rene
  3. lax037
    May 29, 2001
    49
    Long Island
    thanks, what i thought, but wasn't sure
  4. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    you would also be way ahead of the game to use a bellhousing and hydraulic clutch set up from 85+
    otherwise you have to cut a hieous hole in your floorboard to use the mech linkage
    hit the wreckers and get the entire pedal assembly and clutch master from them i think the pedal assembly is usually junk to them so barter as best you can. easiest to find a cab with the interior stripped out and pull the bracket that bolts under the column with the pedal pivots and everything as it will bolt in as a unit. your firewall will have indents where you need to drill for the clutch master and mounting studs
    http://wsphotofews.excite.com/014/j9/fv/QP/LZ21732.jpg
