4spd swap starting tonight.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chevyguybc, Oct 12, 2006.
  1. chevyguybc
    chevyguybc 1/2 ton status
    Nov 12, 2003
    524
    Vancouver Canada
    well, I recently grabbed a set of pedels out of a77 jimmy i parted, got them painted up, tonight im selling my /th350/np203 for 250.Tommaro going to pick up the 465/np205, works great, will probally get it flushed, new bearings, etc slight rebuild, centerforce clutch, etc... id like to convert it to hydrulic,
    or what is recommended for offroad/daily driver..
    my last truck was manual , so i know what its like
    any links to pages about the swap( auto to std)
    going to do the rear 63s finally and stretch the wheelbase to 112, and geta fuel cell tucked into the rear
  2. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    Go hydro if you can find the parts. You'll need the pedal bucket, pedals and rod from clutch pedal to master as well as the clutch master, slave and hydro bell. You can find all this on an '85 or newer pickup or K5.
    Rene
  3. chevyguybc
    Nov 12, 2003
    524
    Vancouver Canada
    hmm, it will be on the wishlist, but most likly staying manual a bit it looks like
  4. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    I don't blame you. I've had a hell of a time finding hydro clutch parts. I have everything now except for the rod that goes from the clutch pedal to the clutch master.
    Rene
  5. chevyguybc
    Nov 12, 2003
    524
    Vancouver Canada
    yeha, just got deposit for my th350 combo, already got it almost all out, just need a hoist to lower it down.. then yank engine..
    its gunna be 350hp... 488. 465 205, 39.5 boggers, 1 ton of course, high steer, for spring.. also tube sliders, bumpers, tarnny skid/xmember( like yours rene) and internal cage..
    should I rebuild the 465 and toss a centerforce at it, i know the seller very wella nd he says its in tight shape.. but he would put a clutch in it.. should i go center force, pros cons
    also what about a rebuild kit off ebay, 150 us with shipping included it looks like, something to think about..
    Im so happy i could finally start building the beast stage 2
  6. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    Go with a Luk Pro-gold clutch. Berts Automotive on King George highway carries Luk clutches. I found this out after my Hays clutch showed up. For the sake of your left leg make sure it's a diaphram clutch and not the three finger (Borg & Beck)
    As long as the tranny didn't have a history of popping out of third I'd just leave it alone.
    Rene
  7. chevyguybc
    Nov 12, 2003
    524
    Vancouver Canada
    got an approx price, and it doesnt pop out of any gear i was told:D
  8. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    I'd change the gear lube and run it. Make sure you don't let your hand rest on the shifter when you're driving it...this is a direct cause of thrid gear pop-out as the pressure you put on the shifter by resting your hand on it wears the shift fork pads out. Easily as bad a habit as riding the clutch.
    Rene
  9. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    best mod i ever did to my truck... click my sig if you wantto se a couple pics, pm me if you have any questions, but this weekend ill be at the hammers :D
  10. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    could you get the hydro parts from LMC or something like that:dunno:
  11. chevyguybc
    Nov 12, 2003
    524
    Vancouver Canada
    well picked up the trans/tacse tonight, goes into reverse real easy.. feels great
    i need a clutch, and i also need to geta broken bolt off in the adapter for the crossmember.. hopefully some lube and a hammer and vice grips get it out, if anything ill weld something on and twist it out, or dril and tap it, etc
    but ive got everything I need for the swap, minus clutch and lubes, looks like a few fresh gaskets on the setup too
    250 cdn and i even got the driveshafts
  12. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    Cool! Make sure to post up some pic's...:waytogo:
    Rene
  13. chevyguybc
    Nov 12, 2003
    524
    Vancouver Canada
    just struggled with the bolt for 20 min or so. grinded flat eges on the tip of the bolt. but still a no go, tried a bfh... i guess i have to tear it all apart and ill bring the adapter into work and heat it out..
  14. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    Go over that adaptor with a fine tooth comb, as they are pretty famous for cracking...
    Rene
  15. bowtiepower00
    bowtiepower00 1/2 ton status
    May 11, 2000
    924
    AZ
    Here's another vote for LUK, pro gold is good but a regular old rep set would work just fine. Dial-a-clutch has pretty good prices too, ordered from them a few years ago.
  16. chevyguybc
    Nov 12, 2003
    524
    Vancouver Canada
    adapter looks great, took them alla part yesterday, today got the oven cleaner and started the battle on cleaning and painting them
    looks as though they both have newer bearings and seals
    rene, where should i go for the tcase to adpater and tranny to adpater gaskits?
    also what gear lube is best for the stuff we do, truck is weekend toy to trails only
  17. chevyguybc
    Nov 12, 2003
    524
    Vancouver Canada
    well ebay looks best bet for gaskets, lordco wanted 75 for just the tcase... can get both trans and tcase kits for under that on ebay.. just gaskets no bearings
  18. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    I've always used RTV...
    Rene
  19. dyeager535
    26,979
