4wd front differential
Discussion in 'The Garage' started by ratchetgmc, Oct 17, 2005.
  1. ratchetgmc
    ratchetgmc Registered Member
    Mar 23, 2005
    11
    gloucester,va
    when placing in 4wd front differential feels like something dragging or not smooth when driving. front driveshaft turning. when shift back to 2wd everthing back to normal. pulled front diff plug to check fluid level after trying a couple of times. looked like chocolate milk. help; this is out of my range of knowledge. 89 fullsize.
  2. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    make sure the front and rear have the same gear ratio
  3. ratchetgmc
    Mar 23, 2005
    11
    gloucester,va
    truck all stock. but good guess; that is exactly what it feels like; only not as noticable as this would feel . thank you for your response.
  4. ratchetgmc
    Mar 23, 2005
    11
    gloucester,va
    would the locking hubs have something to do with this or is this a differential problem
  5. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Are you in dirt? If you are on the street it will drag like crazy.
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    One problem for sure is the "chocolate milk" gear lube. There is water in your gear oil.. :eek1: You need to drain the diff completely, wipe it out as much as possible with rags, then clean it good with a can of aerosol brake cleaner. Once it's all clean inside, re-install the cover and fill the diff will new gear lube.
  7. ratchetgmc
    Mar 23, 2005
    11
    gloucester,va
    yes. always in dirt,sand,snow, or ice when placing any of my solid axle 4wds in 4wd.
  8. hunterguy86
    hunterguy86 1/2 ton status
    Jan 10, 2005
    2,477
    San Marcos, Texas
    DO THIS NOW!! I was always told, and have done, that if your gear oil is milky to change it right away, then put it in 4wd to get the oil to move around then change it again. This enables you to make sure you got all the old milky stuff out.
    Dustin
  9. ratchetgmc
    Mar 23, 2005
    11
    gloucester,va
    does anyone know if the water in the gear oil could actually be felt when driving; this is hard for me to believe but i really do not know.
  10. gambit420s
    gambit420s 1/2 ton status
    May 17, 2005
    294
    KnoxVegas, Tennessee
    you prob wont feel the water but you will feel rusted/seized/spun bearings, maybe even rust on the ring and pinion causing interference
    does your housing/seals leak? have you swamped your axle lately, or in the last few mo's?
    if fluid leaks out, water can get in. and check your vent tube too
    it could also be your joints check/grease them too
    do your brakes drag?
  11. ratchetgmc
    Mar 23, 2005
    11
    gloucester,va
    thank you gambit420s for your help. i need to take some time out of my busy schedule to join this site. this work is to put this blazer up for sale. bought 6 months ago for my wife to drive but have since came across a deal i could not refuse (because my wife told me so). never really drove blazer. nice truck fairly well maintained but i also have a 91 suburban that i have had for years and can`t part with. as for your reply; you may be right on time. would appreciate any more ideas but i have some time off in a few days and i will pull cover to inspect and install fresh gear oil.thanks again for taking time out of your day to help me gambit420s men like yourself is what makes these forums happen.
  12. ratchetgmc
    Mar 23, 2005
    11
    gloucester,va
    thank you for your reply gambit420s.need to take a few minutes out of my busy life to join this site. the work i am doing to this blazer is getting it ready to sell. nice truck that i bought 6 months ago for my wife to drive but have since found a great deal that i could not refuse (because my wife told me so).so now have way too many vehicles and will part with. will join site because i also have another blazer and a suburban that i can`t part with. gambit420s, men like yourself taking time out for others i what makes these sites work. i will post to help others. sorry for the dual reply;thought the first reply did not get submitted.
  13. guido666
    guido666 1/2 ton status
    Feb 16, 2005
    788
    Longmont, CO
    Oil that has water in it is called "emulsified" and basically loses nearly all its lubrication properties. It also turns to a thickened sludge as it gets whipped up by mechanical forces (spinning gears, moving pistons, etc.). This could very easily cause great drag on the axle. I had an engine that blew a head gasket and imulsified the oil, you had to go heavy on the throttle to get it to overcome the drag (No, I didn't run it like this, I just had to get it home a couple miles). The oil change is the first thing to try, if that doesn't work you know that some bearing surface is not doing its job.
    To do a test to help isolate the problem, support the front axle on jackstands. With the transfercase in 4wd rotate one tire (the other should spin opposite). This will test the spindle, hub, and spider gears for the drag, because the transfer case will hold the driveshaft still. If it rolls easy, put it in 2wd, and put one wheel back on the ground. Rotate the raised wheel again, which will isolate the pinion, carrier and transfercase output bearings. If you get some resistance here, disconnect the front driveshaft and you will be able to tell if its in the pinion/carrier or in the transfercase output.
    Hope this helps.
  14. ratchetgmc
    Mar 23, 2005
    11
    gloucester,va
    guiddo666; you are the man. this helps very much. i think this info is better than the shop manuals. your explaination of the results of emulsified oil was right on the money and just what i was looking for; makes since. when i removed a sample of the oil just after running in 4wd for a couple of hundred feet it looked much like a chocolate milk shake (as opposed to my description of chocolate milk). after my drain,clean and refill. i will try your test step by step to attempt to isolate.thanks again guys.
  15. guido666
    Feb 16, 2005
    788
    Longmont, CO
    No problem, good luck.
