4wd indicator light
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by scotto0609, Nov 17, 2006.
  1. scotto0609
    scotto0609 1/2 ton status Premium Member
    Feb 3, 2004
    1,526
    3
    babylon,ny
    I have a 86 k30 dually bb 400/205 combo. If the light is not on is it in 4wd or is it possible it is and not illuminated? When the light is on I know its in 4wd but when its not on i am not sure. I thought when the 205 is in 4wd its in,period.But i am not so sure. Any ideas?:confused:
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    The light should only be ON when IN 4WD
  3. scotto0609
    Feb 3, 2004
    1,526
    3
    babylon,ny
    The light is only on in 4wd,I can here my bad front slipjoint when its on. I guess my question is if its possible to be in without the light?
  4. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    I'd be for checking some things out if that is happening. Whether its the actual case issue or just the light indicator having issues.
  5. dyeager535
    26,979
    Yes, the switch can fail. From my experiences with my 205's and the switch, they are somewhat fragile. Odd, pretty simple piece, but the movement they sense is pretty small, and they can easily "come out of adjustment".
    The whole thing is essentially a ball bearing that rides on one of the shift rails, and that movement opens or closes the switch through a pin sticking out of it. Spring between the switch and the ball bearing to keep tension. Too much or too little movement (bad switch, spring, ball bearing, and so on) and the light won't work right.
  6. ccatlett1984
    ccatlett1984 1/2 ton status
    May 1, 2005
    161
    michigan
    when you push the lever, its in 4x4. go a further and your in 4-Lo
  7. ccatlett1984
    May 1, 2005
    161
    michigan
    the light is there for idiots (hence the name "idiot light")
  8. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,229
    487
    New Hampshire
    where can I get a new switch for my 208?
    *hijack* :D
  9. dyeager535
    26,979
    Prolly GM, since the 205 switch is still out there. If they were *smart* it'd be the same switch as the 241, but this is GM we are talking about :)
  10. Chevy305
    Jan 23, 2006
    11,229
    487
    New Hampshire
    I think I found the switch in Chevy Duty (Classic Parts of America). Sounds like its the correct switch. But the switch actually looks a lot like the reverse switch I replaced in my SM465. Maybe they are the same switch?
  11. dyeager535
    26,979
    Having never dealt with the 208 stuff, can't comment. I do know that the early 465 and later 465 switches use entirely different connectors, and the later 205 4wd switch does as well.
    You might be able to get the piece cheaper from gmpartsdirect or jim here on the board if they are indeed still available. Only a day or so away from my parts manual that should net a part number for you, if interested... You'd be surprised...the aftermarket needs to make money, even if it means buying GM parts at your cost, reboxing them and selling them for a profit. Or finding some dirt floor factory in china that will make knockoffs cheap enough to turn a profit. :)
  12. Chevy305
    Jan 23, 2006
    11,229
    487
    New Hampshire
    I checked GM Parts Direct and they only had the 205 switch. The 208 seems to be a mystery.
  13. dyeager535
    26,979
    That's incorrect:
    GM PART # 14037986
    CATEGORY: All
    PACK QTY: 1
    CORE CHARGE: $0.00
    GM LIST: $17.32
    OUR PRICE: $10.26
    Part number was taken straight out of my GM '85-88 parts manual.
  14. Chevy305
    Jan 23, 2006
    11,229
    487
    New Hampshire
    is that for the 208?
  15. dyeager535
    26,979
  16. chevy wrangler
    chevy wrangler 1/2 ton status
    Jun 15, 2006
    3,035
    el paso, texas
    My Truck Has A 350/465/205 Combo And When I Put It In Reverse The 4wd Light Comes On?? Im Stumped
  17. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    okay a few wires were crossed the blue/green one goes to tranny and the white/black goes to t-case. now the 4wd light comes on when i wiggle the 205 shifter so is the switch bad??where can i get one?? does anybody have pics???
  18. Chevy305
    Jan 23, 2006
    11,229
    487
    New Hampshire
    Well I just picked up the new 208 switch today from my local GM stealership. I am a little pissed that it is the same goddamn switch as the reverse light switch in my SM465. :angry1:
    So after $17.50 for a switch I could have got it way cheaper from LMC. Oh well, **** happens :surepal:
  19. dyeager535
    26,979
    Well, it's good info anyways! I wondered if that later 465 switch was available. Sorry to hear you had to find out the expensive way.
    How much did LMC want? I assume to your door it would have been slightly less from gmpartsdirect.com than the dealership, they always rape you. Almost double the list price I see. Typical.
  20. Chevy305
    Jan 23, 2006
    11,229
    487
    New Hampshire
    well it would have been $10ish from GMPartsDirect but also I just realized that it would have been about $10 for the shipping, so its really 6 to 1 - half dozen to the other. :deal:
