4WD Indicator Light
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by kpanza, Nov 21, 2002.
  1. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    I just had my 208 t-case resealed and re-installed in the K5. Now, when I drive the truck, the 4WD Light comes on, even though the truck is NOT in 4WD (I got out immediately when I saw it and checked). If I yank the shifter back into 4Hi then push it back into 2Hi, the light will go out for a second, then it comes back on. Weird thing is that the light sort of starts out very weakly lit, almost like a glow, then it gets brighter as I drive...
    I checked the plug on top of the t-case, unplugged it and plugged it back in, no change. The only thing I can think of is that the "switch" is bad? You see, I had to swap the front half of the t-case out for another during this process (couple bolt holes were stripped out and previous owner really jacked them up), so the switch is not the same one as before. Truck never did this before.
    Any ideas guys? Should I just replace the switch?
  2. big d
    big d 1/2 ton status
    Oct 24, 2001
    1,236
    illinois
    ya, sounds like bad switch to me.
  3. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
    mine did this same thing, check hte wire that goes from the top of the t case up into the floor. mine was grounding out and making the light come on.
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
