4WD Light?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 82K5_6.5L, Jan 21, 2003.
  1. 82K5_6.5L
    82K5_6.5L 1/2 ton status
    Dec 4, 2002
    439
    Tucson, Az
    hey just curious, on my 82 K5 the four wheel drive light doesnt ever work, but when i go out 4wheelin and bouncing around the light seems to flicker on and off sometimes...does anybody know y it does that?
  2. BrianDamage
    BrianDamage 1/2 ton status
    May 14, 2001
    753
    Alabama
    first thing I'd do is change the bulb
    it might be loose, or more likely the filament is broke, but when you bounce around it is momentarily making connection and lighting up
  3. dremu
    Feb 27, 2000
    15,967
    458
    East of San Francisco
    Could be the bulb, or the socket ... could be the switch on the t-case (shifter? where IS it?) has come loose. That's your basic electrical gremlin; somewhere there's a loose or corroded connection.
    I like my '74 /forums/images/graemlins/k5.gif . No electric much of anything. <big grin>
    -- A
  4. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    There is a printed circut board on the back, make sure you bulb holder is on the contact points. If you put it in and turn it too far or not enough it can do that.
    I know my board has a crack and in the winter the light above the MPH gauge doesn't come on till the truck warms up and contact points expand and make contact again /forums/images/graemlins/smirk.gif
    I have some pics of the gauges if you want to check them out without pulling your send me a PM
    my dash at night after I painted the back of the reflector white (instead of the light blue), now my guages are orange because the reflector reflects the full color spectrum including reds /forums/images/graemlins/smirk.gif oops
  5. 77fixer
    77fixer 1/2 ton status
    Nov 22, 2001
    464
    Meridian, ID 83646
    My 4wd light is not part of the PCB, it is on it's own wiring and just plugs into the back of the cluster.
    Brett /forums/images/graemlins/burb.gif /forums/images/graemlins/k5.gif
