4WD not working HELP!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by madups311, Nov 14, 2001.
  1. madups311
    madups311 Registered Member
    Nov 14, 2001
    72
    VA
    HELP!! I have a 79 jim and the 4WD does not work right. I get out lock my hubs, I get back in put it in nuetral, I put the selector up in 4WD LO, the 4WD light comes on my instrument cluster, I put it in drive and the light goes out, wham no 4WD (same with 4WD HI)...If I put continued pressure on the floor 4WD selector the light will stay on and stay in 4WD...
    this is not acceptable operation...how can I fix this ???
  2. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    First, fill out your profile.
    Second, sounds like you have either -
    1. worn out chain - would require it opened up and replaced.
    2. misadjusted transfer case shifter - can be done without removing the tc from the truck. Get a Haynes manual or better yet the actual factory service books from '79 ONE TON TPI K5 - See it at---&gt;<a target="_blank" href=http://www.blazzinor.rockcrawler.com>www.blazzinor.rockcrawler.com
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Are you sure your 4wd isn't working just because the light goes out?
    Sorry if that's a stupid question, but figured I'd ask the obvious first.
    I think your shifter's out of whack though...NP 203s have a weird looking shifter.
    Tim
  4. madups311
    Nov 14, 2001
    72
    VA
    I know it's not the light, I know the light is just the indicator
  5. Grim-Reaper
    7,385
    Atlanta
    The switch is in the shifter. The Lady;s 79 light was intermitant. Turned out the clip that retains the switch was toast. Small radiator clamp did the trick, Had to do the same trick with the brake light switch on both her 79 and my 75.
    Your probably in 4wd. get on some loose stuff drop it in low and have a bud watch when you hammer it and see if you spin a front tire.
    If it's really poping out of LOC then a few things could cause it. Busted gromits where the rods connect to the shifter is common. I have seen replacments in the help section at Pepgirls. Another biggie on coverted trucks is improperly shimmed part time kits. Grab the rear yoke and pull out and push in on it. you should just feel a 'Hair" of movement. if it is moving a lot then it needs to have the tail shaft reshimmed. Spec is like 1/1000 end play.
    Women dig dents and flat paint!
    coloradok5.com/gallery/Grim
    75 Jimmy, Dollar
    Grim-Reaper
  6. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Did you make sure you have enough 4WD fluid? [​IMG]
    Surgeon General's Warning:
    Viagra and steroids may be harmful to your spouse![​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  7. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    <blockquote><font class="small">In reply to:</font><hr>
    Pepgirls.
    <hr></blockquote>
    <font color=red>LM</font color=red><font color=yellow>AO</font color=yellow><font color=blue>!!!!!!!!</font color=blue>
    Like to go sloppin' 'round in da mud in a rapid fashion....=)
    <a target="_blank" href=http://coloradok5.com/gallery/albun31?&page=1>See my pics here</a>
