4wd pitman arm fit 2wd box?
Discussion in 'The Garage' started by k204dr, Dec 25, 2006.
  1. k204dr
    k204dr 1/2 ton status
    Aug 27, 2004
    463
    TN
    anyone know? tracking down a steering issue, i'm down to changing out the box, but all i got is a 2wd one. will the 4wd pitman arm physically fit the 2wd shaft, or is it different altogether? I know the 2wd is held on by a nut, and the 4wd has a bolt that tightens the arm on. I realize the 2wd one wont fit the 4x4 shaft since its setup for 4 keyways, but didnt' know if the 4x4 one would go the other way. search hasn't helped on this specific problem yet.
  2. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Nope completely different animal.
  3. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    You CAN replace the sector shafts between the boxes and make the 2wd box a 4wd box...
  4. dremu
    Feb 27, 2000
    15,954
    444
    East of San Francisco
    As 79k20350 says, you'll have to swap shafts. Good news: it's easy.
    http://coloradok5.com/forums/showthread.php?t=147102&highlight=sector+shaft+swap
    -- A
  5. k204dr
    Aug 27, 2004
    463
    TN
    thanks, I knew I could swap the sector shaft, but I"m thinkig that may be part of the problem. when i got it it had a mile of play in the steering, and took alot of turns on the adjusting nut to get it close to anything. i'm thinking its worn the sector shaft maybe? guess i'll have to take it off and look. and I threw away 2 spare 4x4 boxes a few months back. :doah:
  6. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    If you need to buy a 4WD sector shaft i have 2 of them.
