4wd shifter problem.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by walt88, Feb 8, 2001.
  1. walt88
    walt88 1/2 ton status
    May 24, 2000
    430
    Monmouth County, NJ
    Every time i have my truck in 4 wheel, i hit a bump and it pops out of 4wd. I have to hold the shifter into 4wd. Is it the linkage?? Thanks?
    <font color=red>Keep the shiny side up, and the greasy side down.</font color=red> wkeil@home.com
  2. californiak5
    californiak5 1/2 ton status
    Oct 25, 2000
    820
    Oceanside, Ca. 92056
    It could be the linkage or it might be the body hitting the stick if you have a body lift. Just my $.02
    Keith
    [​IMG] Born to Drive My K5 [​IMG]
  3. warwagon
    warwagon Guest
    IF YOU GOT A 203 TRANSFER CASE YOU MIGHT WANT TO CHECK THE ADJUSTMENT ON THE LINKAGE. IF IT ISNT RIGHT YOU CAN RUN INTO THE PROBLEM. HOPE YOU FIX IT
