4wd slipping out
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by suntadz, Feb 4, 2007.
  1. suntadz
    suntadz 1/2 ton status
    May 15, 2005
    187
    bay area, ca
    i recently had a new one while 4wheelin. everytime i would let off the gas it would slip back into 2wheel drive. kinda of annoying because sometimes i wouldnt even notice. On some hill climbs my passenger would hold it into 4wd so we could make it up. I have a 208 tranfer and the handle seems a little to ez to move between 4wd and 2wd so big bumps would also knock it back. Im sure this is a common thing and any ideas would be helpful as im a new to this. thanks alot.
    robb
  2. 84 K5 4x4
    84 K5 4x4 1/2 ton status
    Nov 14, 2006
    163
    Jasper Ga
    Ty adjusting your linkage.
  3. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    X2...
  4. fendereff
    fendereff 1/2 ton status
    Jun 24, 2005
    207
    Aggieland, Texas
    i had a similar problem with my 208. It seems to have resolved itself for now, but I havent fully tested it. Linkaage sounds logical, but let me know how that works out for ya.
  5. ccatlett1984
    ccatlett1984 1/2 ton status
    May 1, 2005
    161
    michigan
    the shift forks inside the case are made of aluminium and have nylon pads on the end, over time the pads where down and can cause this, in extreme cases the shift arm itself can start wearing down. the parts are pretty cheap, $15 a piece last time i checked. but you do need to tear down the case to get to them though. If the linkage isnt the issue, then you might consider getting a rebuild kit and the forks (there is a range fork and a mode fork) and doing it yourself. its not very complicated at all. usually its just the mode fork that wears down, since its used a lot more. the range fork that shifts into low range is usually fine, so the truck would not slip out of 4-lo.
  6. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    I had a problem on my 90 with the NP241, the body mounts were rotted and the body was flexing enough to pull it out of 4 hi
  7. trikstark5
    trikstark5 1/2 ton status
    Feb 17, 2004
    169
    usa
    I had the same problem with my '88 Blazer with a NP208. Ended up just having to adjust linkage. My brother is driving it now, he has had no more problems with it dropping out of 4wd.
  8. bigred81
    bigred81 1/2 ton status
    Dec 5, 2003
    323
    Falls City,TX
    If you have to adjust one that normally means something is starting to wear out. I see this a lot in the shop they will adjust once but if you have to keep adjusting it is time to replace the pads or the mode fork which is normally fried by the time you replace them. Check motor and trans mount.
  9. dave_90_blazer
    Jan 1, 2004
    688
    and body mounts
  10. suntadz
    May 15, 2005
    187
    bay area, ca
    Well I just adjusted my linkage according to my manual. hope it works. it does feel alot better and I has a definite snap into the position. Cant tell till my next trip out though. I also noticed the rubber mount looked a little squished out of place. I might try to call ORD and get a new tranny mount tomarrow. Wouldnt hurt to replace that too. Hope I dont have to rebuild it quite yet I need the money for bigger tires. Thanks for the input:bow:
  11. W7NB
    W7NB 1/2 ton status
    Nov 9, 2006
    716
    Springtucky, OR
    I know it sounds goofy but take a bungee cord with you - I had this happening on my heep due to a worn fork and used a bungee cord to hold it in 4 hi till I had time to rebuild the case. Cheesy but it kept me wheeling!
