4wd
Discussion in 'OffRoad Design' started by **DONOTDELETE**, Jan 26, 2001.
    hello i have a 1977mod k5 blazer, have a problem with the 4wd, when i turn it on, the rear weels brakes, hang a little bit, but in 2wd it works youst fine. enybody have some ides??
  1. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    What tranny and t-case do you have? I suspect you have a 203 with a loose chain or a bad diff assembly. You might specify just what you have as for trans and t-case type and maybe post it on the main board also, there's a lot of good troubleshooters there, at least a little more traffic than here.
    Hope this helps
    Making the world better, one truck at a time.
    SW-ORD
